January 15, 2010, 17:24 |
input method for various temperature value
jaikrishna
Rep Power: 17 |
I've thermal conductivity of steel from 400 to 700 degree C at the interval of 25 degree C.
how can i feed it this valves into CFX? from 400 to 700 k-valve is not linear... |
January 15, 2010, 20:52 |
Tristan Burton
Rep Power: 17 |
Create a CEL expression for thermal conductivity as a function of temperature based on your fit to the data (e.g. VarThermConduct=a+bT+cT^2+... where you make sure each of the terms has the correct units) and replace the value for the Thermal Conductivity under the Material Properties tab with your expression (VarThermConduct).
Tristan |
January 15, 2010, 23:07 |
Rep Power: 143 |
Or use a 1D interpolation function. This uses linear interpolation between the points.
January 16, 2010, 13:20 |
jaikrishna
Rep Power: 17 |
please explain the formula elaborately.
thanks. |
January 16, 2010, 15:58 |
Attesz
Rep Power: 17 |
you should make an user function, with two points 400 and 700 K, with step number (700-400)/25. After that you should define an expression, which uses this function. And when you set the temperature, you should set this expression by its name. These steps are well described in cfx help. Good luck!
free stream temperature | qzhu | FLUENT | 5 | June 10, 2015 03:55 |
temperature 1K- 5000K | aga | FLUENT | 5 | October 2, 2006 03:02 |
Static temperature | David | FLUENT | 2 | April 1, 2005 10:57 |
About fix wall temperature in wall boundary | joon | Siemens | 2 | March 10, 2003 01:41 |
Sequential calculation of Temperature and mass tra | J.W.Ryu | FLUENT | 7 | June 18, 2002 07:12 |
