freeware Fortran Compiler?
Old   January 19, 2010, 05:47
Default freeware Fortran Compiler?
Ms Susa is on a distinguished road
Hello everyone!
Does anyone know if it's possible to use an open source/freeware Fortran Compiler with CFX 12?
I tried G95, but when trying the air conditioning tutorial I got an error after entering
! system ("cfx5mkext TStat_Control.F") == 0 or die "cfx5mkext failed";
into the command editor.
ERROR CCL parser failed with message:
Perl Syntax errors detected:
cfx5mkext failed at (eval 113) line 1.
It would be very nice if someone could help me.
Thanks
Ms Susa is offline   Reply With Quote
Old   January 20, 2010, 22:04
stumpy is on a distinguished road
That error has nothing to do with your compiler. Try compiling from the command prompt using:
stumpy is offline   Reply With Quote
Old   January 21, 2010, 07:20
thanks for your answer stumpy
I tried that but I get an error:
A fatal error occured incfx5mkext:
The compiler command "ifort" could not be found. Please ensure that the compiler is on your PATH and try again.
I have installed Intel Visual Fortran Compiler Professional, Microsoft Windows SDK and Microsoft SQL Server.
And I made sure that
C:\Programme\ANSYS Inc\Shared Files\bin
is in the Path of Windows System Variables.
What is wrong?
Old   January 21, 2010, 19:49
So you're on Windows (rather than linux). The intel compiler is the only option. If you were on linux there's free compilers that will work.
Intel Fortran Compiler & Tutorial 17 Young CFX 1 March 30, 2011 01:39
Fortran Compiler and example Young CFX 1 March 22, 2011 22:26
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Fortran compiler Erik Siemens 2 November 28, 2008 20:05
Fortran compiler Arnab Siemens 5 September 14, 2004 03:59
