April 10, 2010, 05:19 |
Moving mesh
Francesco
Rep Power: 16 |
Hello to everyone!
I'm trying to simulate a simple rectangle moving by fluid force. I have a inlet velocity of 1 mm/s on x axis direction. I'd like to calculate the Drag Force and to see the streamlines. I've attached a picture with the CEL expression. When I run the solver and then the post I can see a strange behaviour. The rectangle has an oscillating movement around its start position!!!it's naturally impossible. What am I doing wrong? The second stage is to simulate a rotating rectangle around its bottom face. How can I simulate the rotation with CEL? |
April 10, 2010, 06:31 |
Rep Power: 143 |
In CFX V12 you have two approaches to model this - moving mesh or immersed body. The immersed body option is by far the easiest. CFX support has done demo files doing this sort of thing using both approaches, so talk to CFX support and get the demo files.
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
CavitatingFoam with a moving mesh mass conservation error | idosil | OpenFOAM Running, Solving & CFD | 3 | November 27, 2007 17:27 |
Waves halted by moving mesh | Piotr Czajko | COMSOL | 1 | November 24, 2007 02:00 |
Moving Mesh and MRF | Romain | FLUENT | 1 | May 16, 2002 03:45 |
