How to model blades that intersect each other?
Old   May 14, 2010, 13:11
Default How to model blades that intersect each other?
Adam
Adam1181 is on a distinguished road
I am trying to model fluid flow in a radial turbine that has the shroud side of the blade rounding forward and permanently connecting to the blade in front of it. I am using Solidworks for the design then importing into Ansys 11. I Have modeled the fluid domain and got good results from advanced CFD(ansys workbench), but I need to get rotational data. I have a few questions.
1. Is it possible to do this with Turbo grid? If so how do I define the shroud curves and what settings do I need?
2. If I can't use Turbo grid what can I use (ICEM CFD or advanced CFD)?
Any help would be greatly appriciated.
Adam1181 is offline   Reply With Quote
Old   May 16, 2010, 12:39
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Experts are here: http://www.cfd-online.com/Forums/ansys-meshing/
Attesz is offline   Reply With Quote
multiphaseInterFoam for RAS turbulence model chiven OpenFOAM Bugs 8 December 6, 2017 02:08
2 stage axial turbine model convergence issues sherifkadry CFX 2 September 7, 2009 20:51
multi fluid mixture model issue rystokes CFX 3 August 9, 2009 19:13
algebraic slip model with stirred suspension? Manuel Krause CFX 0 April 15, 2005 09:10
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 03:27
