Error massage GETCORE stacktrace
Old   February 9, 2012, 04:53
Default Error massage GETCORE stacktrace
Pisut
bitkiz is on a distinguished road
I simulate water-air mixing tank with three domain with MRF technique. I am using the stage interface between impeller domain and tank domain. When I select the constant bubble size and stage interface, there is no problem with my simulation.
The problem occurs when I change the constant bubble size function to polydispersed fluid (MUSIG). I had a model that run fine but the simulation crash when it writes the result files or back up files. The error message is
GETCORE stacktrace
1 SU_HYBARR, ,DIAM_FL2,ZN1 /VERTICES,LATEST
2 GATHER_CS_CSIP, ,SIZFRC_SG1_MF1,ZIF2 /CS,LATEST
3 GATHER_CS_CSIP, ,SIZFRC_SG1_MF1,ZIF6 /CS,LATEST
Waiting for your reply. Thanks
bitkiz is offline   Reply With Quote
