January 25, 2010, 11:51 |
CFX and i7
Fatema Zandi Goharrizi
Rep Power: 17 |
Hi
would any one help me with using full capacity of an i7 system on cfx runs. actually I use a system with an intel i7 920 cpu and 8 GB RAM and have cfx 11 but I just can use 4 cores on my runs and it gives errors due to licence if I'm right. thanks |
January 26, 2010, 02:52 |
Michiel
Rep Power: 16 |
I assume Ansys CFX has the same license configuration as the Mechanical modules. In that case the number of cpu's is limited at 2 for one license. If you want to use 4 cpu's you should buy a second license.
January 26, 2010, 10:29 |
Rep Power: 17 |
Hi
thank you I can get run with 4 core but not 8 would you please tell me if I have buy license for 8 or for 4 to run with 8 core of an i7 thanks again |
January 26, 2010, 16:34 |
Rep Power: 143 |
You will need to buy additional licenses to run 8 processes. But don't bother. The I7 chip has 4 cores so running any more processes on it is bad. It looks like 8 processes on task manager as each core looks like 2 cores due to hyperthreading - but CFX does not take advantage of hyperthreading so you do not gain a useful speedup by using 8 cores.
Unless you have a dual CPU system, then you do have 8 cores. Then you just need to get that many licenses to run it. |
January 27, 2010, 04:56 |
#5 | |
Rep Power: 17 |
Would you please say how I can understand that a system is dual cpu system or not? What do you mean by many licenses exactly? Thank you |
January 27, 2010, 15:51 |
Rep Power: 143 |
Did you get a computer with 1 CPU or 2? If you can't answer this then open the box and have a look!
Parallel licenses are per-process. You need 8 to run an 8-way parallel job but only 4 to run a 4 way parallel job. |
January 28, 2010, 02:49 |
Rep Power: 17 |
June 4, 2010, 11:01 |
YongQiang Chi
Rep Power: 15 |
I guess hyper threading may help....very little bit of CFD formance. It won't worth the price of licensing for the extra 4 virtual cores and just get less than 20% improvement.
Take a look this: http://techreport.com/articles.x/18581/14 |
June 5, 2010, 05:31 |
#9 |
Rep Power: 143 |
CFX has not been complied to use hyperthreading. Don't use it. Just leave the virtual cores sit idle or even better disable them in the BIOS.
8 core, cfx, cpu, i7 cpu, intel i7 920 |
