June 17, 2010, 07:18 |
cyclone separator multiphase help
siddharth
Rep Power: 15 |
I am trying to model cyclone separator in CFX. Based on the previous help from this forum i modeled both air and aluminium particles as continuous medium. the solution converged after 1000 iteration.
Now i am trying to model air as continuous medium and aluminium as particle transport solid. i have used uniform particle distribution with min and max dia as 1micron and 100 micron respectively.For turbulence i have used SSG reynolds stress model. I have used point cone for particle injection. The solution is not getting converged and it is oscillating. I have attached the ccl file. I really need some help Thank you siddharth ------------------------- cyclone_multiphase_v5_5_002.zip |
June 17, 2010, 08:17 |
Rep Power: 143 |
Reynolds stress turbulence models are always hard to converge. I seem to remember telling you this before - only use a RSM model if you really need it and for a particle transport model I doubt you need it.
Here are some tips: http://www.cfd-online.com/Wiki/Ansys...gence_criteria |
June 17, 2010, 08:25 |
siddharth
Rep Power: 15 |
I choose SSG be cause it gave the better solution when both air and aluminium were continuous fluid
I am going to try with Shear stress model. Is this model ok for particle transport model? Thanks Siddharth |
June 17, 2010, 19:38 |
Rep Power: 143 |
As I said previously, if you are adding the complexity of a particle transport model then the last thing you need is making convergence even more difficult by using a RSM model. The extra "accuracy" you get from a RSM model will probably be lost in the multiphase behaviour anyway so there is little point. So SST is a much better choice. Only go to RSM if you can clearly show that SST is inadequate.
June 17, 2010, 23:47 |
siddharth
Rep Power: 15 |
I tried with SST. The solver ran for 1000 iterations. The solution is not converged. It is still oscillating. And the domain imbalances are huge. Really need some help.
Thanks Siddharth |
June 17, 2010, 23:50 |
Rep Power: 143 |
Have you tried the tips on the cfd-online wiki page?
Inconsistent results in cyclone modeling | Boris | CFX | 4 | December 23, 2009 03:36 |
pulverized coal cyclone burner | Manuel Acosta | FLUENT | 9 | May 24, 2007 05:04 |
How to mesh the worm-inlet cyclone | Fuping Qian | FLUENT | 0 | July 7, 2005 03:59 |
cyclone meshing | Tom Robin | FLUENT | 1 | September 16, 2004 06:58 |
Modelling Industrial cyclone behaviour | Günther Hasse | Main CFD Forum | 3 | October 12, 1999 19:34 |
