Cross Flow cooling system involving multiple fluids and a solid domain |
Ajay Menon
Rep Power: 0 ![]() |
I am trying to perform a conjugate heat transfer analysis of a simple cross flow cooling system consisting of a single pipe carrying hot fluid.This pipe-fluid system is cooled by forced convection by air flowing over the pipe. I have gone through the tutorial on CHT of heating coil , but it contains a single fluid domain and a single solid domain. How can I model a CHT transfer such as the one that I described where 2 fluids seperated by a solid domain is involved? Do I need to perform a multiphase analysis here, because CFX just allows me to define one fluid model for both fluid domains or is there a way I can specify seperate fluid models for the 2 fluid domains in my problem? Any help in modelling this problem is appreciated? Thank You Ajay |
Rep Power: 143 ![]() ![]() ![]() ![]() |
This can be done without requiring multiphase. You have to use the "disallow constant domain physics" option or something like that - search the forum for it, there are a few posts on it.
Ajay Menon
Thank You Glenn
Ali Emadi
Rep Power: 15 ![]() |
Dear Ajay
I have exactly the same problem in modelling a heating device. have your problem solved? I searched the forum for "disallow constant domain physics" but nothing exist. Thanks Ali |
conjugate heat transfer, crossflow cooling, multi domain |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 13:00 |
Modeling 2-phase flow in a 3-D system consisting of 3 distinct sections | CFDUSER-A | FLUENT | 0 | December 9, 2009 06:48 |
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 21:25 |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 03:30 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
