how to operate CFX on cluster (no gui)
Like Tree2Likes
  • 1 Post By imnull
  • 1 Post By imnull
Old   January 18, 2013, 13:48
Default how to operate CFX on cluster (no gui)
Dmitry
imnull is on a distinguished road
Hi All,
My CFX tasks requires to set physical time (time step in sec).. On the workstation I can easily change the time step during the process of converging monitoring.
question:
Is any way to set up time step on certain iteration and create *.def to be solved on a cluster (no gui) after?
Thankx,
me
imnull is offline   Reply With Quote
Old   January 18, 2013, 14:37
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
I'm not sure if I totally understand your question but you can use cfx5cmds to read a def file into a ccl file which you can then change and write the new ccl back into the def file. Or you can put the new timestep information into a ccl file and append it at runtime using the -ccl option on cfx5solve. Is this what you are after, or no?
cdegroot is offline   Reply With Quote
Old   January 18, 2013, 15:02
Dmitry
ah.. typed in CL: cfx5cmds -help %)
could you pls write a command line (as an example to change time step) thankx in advance
Old   January 18, 2013, 15:13
cdegroot's Avatar
Chris DeGroot
Let's say you have a def file called test.def. You would type cfx5cmds -read -def test.def -ccl test.ccl to read the command language from the def file into a ccl file that can be changed. In test.ccl you will find something like:
CONVERGENCE CONTROL:
Maximum Number of Iterations = 100
Minimum Number of Iterations = 1
Physical Timescale = 1 [s]
Timescale Control = Physical Timescale
END
Edit the physical timescale line to what you want. Then type cfx5cmds -write -def test.def -ccl test.ccl to write the new command language to the original def file. The def file will now contain the new ccl commands.
Hope that helps.
Old   January 18, 2013, 17:26
Thumbs up
Dmitry
let's say you have a def file called test.def. You would type cfx5cmds -read -def test.def -ccl test.ccl to read the command language from the def file into a ccl file that can be changed. In test.ccl you will find something like:
Convergence control:
Maximum number of iterations = 100
minimum number of iterations = 1
physical timescale = 1 [s]
timescale control = physical timescale
end
edit the physical timescale line to what you want. Then type cfx5cmds -write -def test.def -ccl test.ccl to write the new command language to the original def file. The def file will now contain the new ccl commands.
Hope that helps.
!!!thanks!!!
Works ok
Old   January 21, 2013, 22:38
Dmitry
btw: there is another way to set up time in -PRE.... 300*1e-6, 100*1e-4 [s] meas 300steps at 1e-6s and 100steps at 1e-4s right after first 300steps
Aktigridia likes this.
Old   March 17, 2014, 10:37
Default question about time
Ksenia
Aktigridia is on a distinguished road
imnull, could you please tell me in what field do you print this
300*1e-6 and etc ?
Thank you in advance!
Aktigridia is offline   Reply With Quote
Old   April 25, 2014, 09:34
Dmitry
300*1e-6 and etc ?
here is a prtscrn (in pre-)
Old   March 17, 2021, 05:45
YangLu
yanglu is on a distinguished road
Can i use the 300*10,100*1 for the output frequency? I want to export the Trn results every 10 timestep in the first 300 timestep and every 1 timestep after 300 timestep?
yanglu is offline   Reply With Quote
Old   March 17, 2021, 06:23
YangLu
Hi, I tried to input the command from the prompt but it shows that the cfx5cmds command not found. Could you please tell me what I did wrong?
Thanks.
Yang
Old   March 17, 2021, 09:27
Gert-Jan
Gert-Jan will become famous soon enough
Probably. But why not give it a try?
Gert-Jan is offline   Reply With Quote
Old   March 17, 2021, 16:44
The OS probably cannot find the cfx5cmds command because it is not on the path. The best way to fix this is to use a command editor started from the CFX Launcher as that has all the paths correctly set. So redo it from a command line started from the CFX Launcher.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   March 17, 2021, 18:31
YangLu
It is impossible to input the multiply in the box. Maybe there is other way to do that.
Old   March 17, 2021, 18:36
YangLu
I need to load CFX first to use the command. But I want to edit the settings of the run in progress. I changed the timestep interval of the .def file but the simulation output frequency does not change.
Old   March 17, 2021, 18:47
I am not sure edit run in progress is supported from the command line. The normal way of doing it is with the Solver Manager.
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
heat generation in CFX Ema CFX 4 August 7, 2009 05:39
CFX 10's solutions differ from CFX 5.7's Atit Koonsrisuk CFX 4 July 26, 2006 11:59
CFX distributed computing: Cluster design Q Joe CFX 7 July 11, 2006 10:21
FSI using CFX and ANSYS Bi Chang CFX 2 May 10, 2005 04:47
