January 17, 2011, 04:29 |
RPI Wall Boiling Problem
Ali Emadi
Dear all Friend
I have a problem with a subcooled boiling model. I'm looking for some help from people who are familiar with the RPI Wall boiling model in CFX I am trying to model boiling in a straight heated tube. The problem is set up by steady,constant property material,both as continuous fluid,buoyant,Homogenous turbulence,mixtuer two phase model and RPI wall boiling model. My problem is as following: Depending on the problem condition the calculation crashes after some number of iterations following a huge number repetitions of the following message: " cal_TSUP1 WARNING: Changing upper bound for heat partition algorithm " and at the end the error message is the following: " ERROR #001100279 has occurred in subroutine ErrAction. Message: Heat partitioning algorithm failed to fix upper bound of bisection Details of error:- ---------------- Error detected by routine FNDFIL CFNAME = * CRESLT = OLD " Can anybody help about this problem? thanks to all Ali Emadi |
March 24, 2016, 06:30 |
Rpi model
abubakar izhar
Rep Power: 10 |
Try to set physical time-scale to 0.02 sec or lower for steady state simulation.
March 28, 2016, 18:16 |
Rep Power: 143 |
You are doing quite a specialised simulation so you should expect some difficult convergence issues. This is not a simulation to be attempted by a beginner.
I have no specific experience in what you are doing so cannot help you directly, other than the general tips listed in this FAQ: http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F |
May 18, 2018, 08:30 |
#4 | |
Sibel
Rep Power: 9 |
Now I have the same problem. Could you explained to me that how did you solve this problem?
Thanx Quote:
September 1, 2018, 21:14 |
Soumitra Vadnerkar
Rep Power: 7 |
boiling, rpi, two phase flow |
Quenching simulation - wall boiling model | Michael.J | CFX | 10 | August 27, 2013 17:02 |
Problem Interface Solid Fluid with wall velocity Solver v12 | hills1 | CFX | 2 | October 12, 2009 05:36 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
moving wall BC problem | Sourabh | Main CFD Forum | 1 | August 8, 2006 07:47 |
The problem of wall data getting when postprocessi | WIlliams | Siemens | 4 | March 6, 2006 10:14 |
