March 10, 2011, 04:08 |
Fortran Compiler-CFX12.1
Araz
Rep Power: 15 |
I have seen many posts about my problem but I'm still very confused, I hope you guide me in this regard: I want to redesign the geometry of a compressor blade using CFX 12.1. I have my Fortran code which accounts for the movement of the blade wall. According to cfx manual and tutorial19 (Air Conditioning Simulation), in order to use my code + cfx, I will need to compile my Fortran code using Intel Visual Fortran Compiler. CFX manual says that: "The Intel Fortran 10.1 IA32 compiler is the recommended and supported compiler for ANSYS CFX 12.0". My machine is Windows XP 32 bit. and I have trial versions of Intel® Visual Fortran Composer XE 2011 and Microsoft Visual Studio 2010. I want to know whether CFX 12.1 support these softwares or I should only install the fortran compiler v10.1? I have also "Microsoft Visual Studio .NET 2003" and "compaq visual fortran 6.6" installed on my os. I will be grateful if someone tell me what is the best option for me Thanks a lot |
March 10, 2011, 04:17 |
#2 | |
catherina
Rep Power: 17 |
In my experience, all compiler versions work, when home tonight will give you the particulars. What I found tricky when installing was setting the paths correct, you might need some manual tweaking, but otherwise you are good to go. Best Cat Quote:
March 10, 2011, 23:08 |
Araz
Rep Power: 15 |
Hi Dear Catherina,
Thank you for your post, I tried the trial versions and it worked, I ran "ifortvars.bat" in cfx launcher command line and added the followings to environment variables: include: C:\Program Files\Intel\ComposerXE-2011\compiler\include;C:\Program Files\Intel\ComposerXE-2011\compiler\include\ia32 lib: C:\Program Files\Intel\ComposerXE-2011\compiler\lib;C:\Program Files\Intel\ComposerXE-2011\compiler\lib\ia32 PATH: c:\ANSYS Inc\v121\CFX\bin;C:\Program Files\Intel\ComposerXE-2011\bin;C:\Program Files\Intel\ComposerXE-2011\bin\ia32;C:\Program Files\Intel\ComposerXE-2011\redist;C:\Program Files\Intel\ComposerXE-2011\redist\ia32;C:\Program Files\Intel\ComposerXE-2011\redist\ia32\compiler;C:\Program Files\Intel\ComposerXE-2011\redist\ia32\mkl;C:\Program Files\Intel\ComposerXE-2011\redist\ia32\mpirt Now, I have two questions: 1- I didn't add any PATH from vs2010 to environment variables since it had already included the old versoin of my vs. However, before installing this new version (vs 2010)I wasn't able to install fortran compiler completely because it couldn't find a supported Microsoft development environment on my pc. so, I don't know which of them is integrated to fortran compiler now? 2- Is "using fortran compiler" the only way to import our own subroutines in cfx? I mean, is it possible to use another programming language like C++ or something else, or even insert our code by hand into cfx in order to get rid of need for fortran compiler? Thanks a lot |
May 12, 2011, 06:47 |
xiaofeng
Rep Power: 15 |
Dear Araz:
I install the same software as you, except I use the Windows7-32bit. As you say,"ran "ifortvars.bat" in cfx launcher command line".I run it ,but there will be some errors.Could you tell me the details,thanks a lot.My E-mail is xiaovsfeg@163.com |
May 12, 2011, 17:07 |
Araz
Rep Power: 15 |
Hi Xiaovsfeg,
In order to run the "ifortvars.bat", you should find its location under the composer installation directory, for my case it was located at: c:\Program Files\Intel\ComposerXE-2011\bin\ifortvars.bat just copy and paste the path in the launcher command line and remember to surround the command with quotes ("), i.e.: "c:\Program Files\Intel\ComposerXE-2011\bin\ifortvars.bat" visit the following link for more information and follow the instructions : http://www.mail-archive.com/nmusers@.../msg02986.html Regards, Araz |
May 12, 2011, 23:42 |
xiaofeng
Rep Power: 15 |
Dear Araz:
1.Thanks for your reply.I run the "c:\ProgramFiles\Intel\ComposerXE-2011\bin\ifortvars.bat"in cfx launcher command line. It appears the follow situation, I don’t know what that means? or you meet the some problems. 2.I added the include\ path \lib\to the environment variables by my computer- property- environment variables. ERROR CCL parser failed with message: Perl Syntax errors detected: syntax error at (eval 14) line 2, near ""cfx5mkext failed" $cclmain:2" The message “The compiler commamd ‘ifort’ could not be found.please ensure that the compiler is on your PATH and try again” My question is what is the “ifort” and how to compile on the the ‘path’. Thanks Xiaofeng |
May 13, 2011, 00:30 |
Araz
Rep Power: 15 |
The attachment shows that "ifortvars.bat" has been run.
But it is not enough for compiling a Fortran routine, Check if you have put the following in the environment variable ? PATH:"c:\ANSYS Inc\v121\CFX\bin" be careful of the correct location of the "bin" file in your pc. |
May 13, 2011, 05:52 |
xiaofeng
Rep Power: 15 |
Dear Araz:
Thanks for your help ,I added the path:PATH:"c:\Program files\ANSYS Inc\v121\CFX\bin"in the environment variable.But the message as the following picture. so I think it's compiling a Fortran routine.It can be some error I don't find.I think you can give me some Suggestions.Thaks a lot . |
June 1, 2011, 10:01 |
#9 | |
June 1, 2011, 21:13 |
#10 | |
xiaofeng
Rep Power: 15 |
1.Install compaq visual fortran 6.0 . 2.Change environment variables in the installation process. 3 Creat the new file in the CFX Root directory.Find and copy the .F and CFX5maket.dll files to he directory.Modify CFX5maket.dll files to correspond the compaq visual fortran.Note:In the CFX5maket.dll "# "Representative comments lines. 4 Run. Best wishes. |
June 2, 2011, 08:11 |
#11 | |
Thank you very much. I decide to change the Fortran finally.
February 14, 2012, 07:36 |
#12 |
AKS
Rep Power: 14 |
Dear xiovsfeg
can i use compaq visual fortran 6.5 for windows x64 using Ansys 12.1. |
November 2, 2014, 12:46 |
#13 | |
hesam
Rep Power: 12 |
Hi, dear Araz
At first I wanted to thank u for your helpful post, I've dove everything u said but after I run "ifort pt_mom_source.F" in the command line the following error appears, ifort: error #10037: could not find 'link'. what do u suggest I do? thanks again. Quote:
March 27, 2017, 05:37 |
#14 |
Tony
Rep Power: 10 |
I got the same problem and solved it finally.
The error is ifort: error #10037: could not find 'link'. I saw this error after running 'cfx5mkext test.F' or 'ifort test.F'. When I run ifortvars.bat in C:\Program Files (x86)\Intel\ComposerXE-2011\bin to setup environmental variables of IVF, it shows that VS2010, which I have installed, has not been detected. I think the error means something goes wrong with the environmental variables of VS2010 (or other IDE you are using). Since I have modified some files of IVF, I uninstalled it first. I run vcvars64.bat in command line to set the environmental variables of VS2010. The file is in E:\VisualStudio\VC\bin\amd64 for my computer. Then I re-install IVF and run 'ifortvars.bat intel64 VS2010' in command line after installation. No error is threw this time. Then I manage to compile my FORTRAN file. |
Intel Fortran Compiler & Tutorial 17 | Young | CFX | 1 | March 30, 2011 01:39 |
Fortran Compiler and example | Young | CFX | 1 | March 22, 2011 22:26 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Fortran compiler | Erik | Siemens | 2 | November 28, 2008 20:05 |
Fortran compiler | Arnab | Siemens | 5 | September 14, 2004 03:59 |
