March 13, 2011, 09:53 |
Resistance Loss Coefficient
K. D.
can someone tell me how to calculate the "Resistance Loss Coefficient" and/or the "Linear Resistance Coefficient" for use in the CFX Porosity Settings Tab? Found nothing on the web unfortunately, so thanks a lot in advance! Last edited by drb764; March 13, 2011 at 10:20. |
March 13, 2011, 18:01 |
Rep Power: 143 |
You use the coefficients to match a porous medium to experimental results. Do youy have experimental results?
March 13, 2011, 22:44 |
Ji Guozhao
make use of you experiment data of pressures and velocities. you can refer the equation 1.146 in ANSYS CFX-Solver Theory Guide, at page 33. then you can obtain Kperm and Kloss via your experimental data. you can contact me if you like, because i just studied that days ago.
g.ji@uq.edu.au |
March 14, 2011, 06:14 |
K. D.
what i have are the laminar and turbulent permeabilities k1 and k2 which correspond to this equation:
dP/L = mu/k1 * U + rho/k2 * U^2 Looks similar to the equation in Solver Theory Guide, but are these the values I need? Thank you so far! |
April 21, 2014, 02:28 |
Rep Power: 12 |
Hi Gentlemen,
I am on the process of calculating the Linear & Quadratic loss coeff. Via experimental Data (V vs P) but the equation im getting from the graph is giving a negative (-) Value for permeability. Please Help me remedy this problem. Thank you very Much. -will |
Quadratic resistance Coefficient | Ramana | CFX | 4 | November 26, 2012 16:25 |
Porous loss model coefficient query | siw | CFX | 7 | August 24, 2011 07:41 |
viscous and internal resistance coefficient in porous media | bansal_vikas1 | FLUENT | 12 | October 6, 2010 08:28 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
Quadratic Resistance Coefficient | Ramana | CFX | 0 | January 2, 2006 03:43 |
