March 29, 2011, 07:00 |
Recirculation zone over airfoil in SST model
Nick
Rep Power: 15 |
Hi everyone,
I've run a simulation at Re=120000 over a thick airfoil using the SST model. The solution converges and in the post I can see a re-circulation zone towards the trailing edge. I was wondering whether this is due to a turbulent boundary layer separation or laminar. Does the plain SST (no transition) mean the entire foil has undergone a turbulent boundary layer and its separation in this case? Regards, Nick |
March 30, 2011, 01:53 |
#2 | |
Raashid Baig
Rep Power: 16 |
http://www.cfd-online.com/Forums/mai...-airfoils.html |
March 30, 2011, 19:15 |
Rep Power: 143 |
If the transition model is not enabled than the turbulence model assumes the flow is turbulent everywhere.
So if you see a recirc using this model then it is a "normal" separation, not a laminar separation bubble. |
March 30, 2011, 20:11 |
Nick
Rep Power: 15 |
Thanks Glenn. Just to clarify. So you mean it's the turbulent boundary layer that has separated ?
March 30, 2011, 20:15 |
Rep Power: 143 |
If you have not enabled turbulence transition model then it is using a fully turbulent model and boundary conditions everywhere. But if there is significant laminar flow about then the simulation will be inaccurate and the results rubbish.
March 30, 2011, 20:24 |
Nick
Rep Power: 15 |
I see. Thanks. Do you know of any resources that I can use to learn about cfx transition modelling? I need to learn about it as soon as possible.
March 30, 2011, 20:27 |
Rep Power: 143 |
The references listed in the documentation are the main ones. From time to time ANSYS also runs Advanced turbulence modelling courses and these go into the transition model in detail.
March 30, 2011, 20:43 |
Nick
Rep Power: 15 |
Much appreciated.
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 13:57 |
Understanding k-omega SST model source code | tmhonka | OpenFOAM Programming & Development | 1 | September 8, 2009 07:33 |
SST model and boundary layers | Rodrigo Basniak | CFX | 7 | March 27, 2008 14:19 |
SST model help please! | Sheila | Siemens | 2 | September 6, 2004 22:39 |
k-w SST model keeps promise ? | Mark Render | Main CFD Forum | 0 | November 30, 2000 07:03 |
