Recirculation zone over airfoil in SST model
Old   March 29, 2011, 07:00
Default Recirculation zone over airfoil in SST model
Nick
Nick R is on a distinguished road
Hi everyone,
I've run a simulation at Re=120000 over a thick airfoil using the SST model. The solution converges and in the post I can see a re-circulation zone towards the trailing edge. I was wondering whether this is due to a turbulent boundary layer separation or laminar. Does the plain SST (no transition) mean the entire foil has undergone a turbulent boundary layer and its separation in this case?
Regards,
Nick
Nick R is offline   Reply With Quote
Old   March 30, 2011, 01:53
Raashid Baig
cfd_newbie is on a distinguished road
Originally Posted by Nick R View Post
Hi everyone,
Regards,
Nick
Hi I think you should take a look at the following forum thread, similar issue has been discussed in detail there -
http://www.cfd-online.com/Forums/mai...-airfoils.html
cfd_newbie is offline   Reply With Quote
Old   March 30, 2011, 19:15
If the transition model is not enabled than the turbulence model assumes the flow is turbulent everywhere.
So if you see a recirc using this model then it is a "normal" separation, not a laminar separation bubble.
Old   March 30, 2011, 20:11
Nick
Thanks Glenn. Just to clarify. So you mean it's the turbulent boundary layer that has separated ?
Old   March 30, 2011, 20:15
If you have not enabled turbulence transition model then it is using a fully turbulent model and boundary conditions everywhere. But if there is significant laminar flow about then the simulation will be inaccurate and the results rubbish.
Old   March 30, 2011, 20:24
Nick
I see. Thanks. Do you know of any resources that I can use to learn about cfx transition modelling? I need to learn about it as soon as possible.
Old   March 30, 2011, 20:27
The references listed in the documentation are the main ones. From time to time ANSYS also runs Advanced turbulence modelling courses and these go into the transition model in detail.
Old   March 30, 2011, 20:43
Nick
Much appreciated.
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
Understanding k-omega SST model source code tmhonka OpenFOAM Programming & Development 1 September 8, 2009 07:33
SST model and boundary layers Rodrigo Basniak CFX 7 March 27, 2008 14:19
SST model help please! Sheila Siemens 2 September 6, 2004 22:39
k-w SST model keeps promise ? Mark Render Main CFD Forum 0 November 30, 2000 07:03
