April 6, 2011, 12:26 |
CFX to ABAQUS
Heather
Hello Everyone
I kept searching for a way to transfer fluid analysis form ANSYS CFX to ABAQUS and unfortunatley I couldnt find a solution to this problem to be more specific on what I mean: If we want to make a fluid-mechanical analysis then we have to make fluid analysis first and then transfer the results of concern (pressure, velocity, .. etc) to ABAQUS at which ABAQUS will read those results and use them directly. So I would really appreciate it if anyone can help Thanks alot |
April 6, 2011, 18:41 |
Rep Power: 143 |
CFX has tight links to ANSYS. To try to link it to another code seems pointless to me.
CFX used to have hooks into MPCCI which could be used to tie CFX to just about any code. I am not sure if they have been removed recently as MPCCI is not required to link CFX and ANSYS, and the link between CFX and ANSYS is far better than anything MPCCI could do anyway. |
April 6, 2011, 19:48 |
Heather
heyyy Glen
Thanks alot for your reply,well as far as I was told there is a way and I've been searchin for it for a while now so I really hope someone can help out soon. |
April 7, 2011, 07:29 |
Rep Power: 143 |
I told you what it was - MPCCI (http://www.mpcci.de/mpcci/why-to-use-mpcci.html).
January 27, 2012, 10:20 |
Abaqus 6.11 has interpolating mapping
Max Leadley-Brown
Hi, I know this is probably a bit late, but the latest version of Abaqus has a capability to import 3rd party results and map them onto a mesh. It can take x y z location points and a scalar quantity and map to an Abaqus mesh, with geometric interpolation between the mesh points.
January 29, 2012, 05:19 |
Rep Power: 143 |
Sure, but can it do a coupled simulation between abaqus and the other code? That is another thing again and the only way I know of doing it which does not involve writing lots of code yourself is with MPCCI.
May 28, 2013, 04:54 |
how can i transfer fluid analysis form ANSYS CFX to ABAQUS ?can u tell me the detail?
#7 | |
lee
May 28, 2013, 06:08 |
Rep Power: 143 |
This is very easy in ANSYS Mechanical - CFX and ANSYS Mechanical have been designed to easily share information. But ABAQUS will be tricky. You will probably have to write out the temperature as a text file and import it into ABAQUS.
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 13:22 |
CFX Export API to ABAQUS | Jeff | CFX | 0 | June 12, 2007 14:05 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 05:59 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
