April 20, 2011, 06:56 |
Blood flow in aorta
Marko Milasinovic
Hello. I need to determine physical dimensions of blood flow in abdominal aorta. Can you tell me how to insert profile velocity in function of time as inlet boundary? I attached velocity function of time.
April 20, 2011, 18:58 |
Rep Power: 143 |
A user function with a 1D interpolation will do it easily.
April 21, 2011, 04:11 |
Marko Milasinovic
Can you describe how to do it?I started recently to use CFX.
April 21, 2011, 11:33 |
Function
Govindaraju
Dear friend
I am also doing the same problem . I want to know how did you get the graph? what function did you use to get the graph? I also need this answer. please give your answer if you find. Thank you Govind |
April 22, 2011, 11:22 |
Ugly Kid Joe
April 22, 2011, 12:25 |
Marko Milasinovic
My professor is working with vascular problems. He measured blood velocity in coronal arthery. I adjusted his values for my problem.
April 26, 2011, 06:35 |
Govindaraju
Dear milasko How your professor got the values .what function did he use for getting number of values. if he uses any function like sin or cos please let me know.I need it urgently. I assume that without a function cannot get number values . am I right? what equation did he use to plot the graph? Thank you kmgraju |
April 26, 2011, 11:32 |
Marko Milasinovic
I think that he performed examing on the pacient.I didn`t ask.The reason is that he is not at my department, I took exam because I earlier worked in FLUENT some simple cases.
July 2, 2011, 07:14 |
Marko Milasinovic
I fill out csv file format for profile boundary condition. when I try to initialise profile data I receive error "Invalid data heading seen in profil `ulaz` at line 8. Between 1 and 3 spatial field names must be specified." Can you tell me what is wrong? I attached picture of profile boundary condition.
July 4, 2011, 02:33 |
Lance
Rep Power: 22 |
"Between 1 and 3 spatial field names must be specified."
You specify X,Y,Z,t == 4 "spatial" fields. If you want to include time you must remove one of the spatial fields. |
July 4, 2011, 04:41 |
#11 |
Marko Milasinovic
Ok.I understand. I didn`t know that I can`t specify more than 3 fields.Thanks a lot.
February 7, 2012, 16:38 |
#12 |
Lauren Dransfield
I realise this is a few months old, but was wondering about something similar, I've looked through the website that was suggested and wondered what the spacial fields actually represent? At the moment I just have time and velocity
February 8, 2012, 03:00 |
#13 |
Marko Milasinovic
Spatial fields have function to identify nodes positions to which you have dedicate velocity
February 8, 2012, 10:07 |
#14 |
Lauren Dransfield
That makes sense and is what I suspected anyway, but when I run my simulation it seems to not let me view more than one time-step, I only have 0, though the function file I made says it should last 1 second, do you know how I'd fix this so I could view it at different points within my 1 second?
February 8, 2012, 12:07 |
#15 |
Marko Milasinovic
Take a look on 5th post.You would notice that you need to set different time value for other steps
February 8, 2012, 13:33 |
#17 |
Marko Milasinovic
Yes, like that
February 8, 2012, 13:36 |
#18 |
Lauren Dransfield
I had done that before, what I'm asking is if there is a way to view the fluid at say the first time-frame and the last, similar to the example in the 5th post? I can't find this...
February 9, 2012, 11:08 |
#19 |
Marko Milasinovic
you need to perform calculation and after that using CFD-Post you can see fluid velocities
February 9, 2012, 18:42 |
#20 |
Shashwat
Hi
Is your flow in the x direction? |
Pulsatile blood flow | John H | FLUENT | 7 | March 3, 2022 07:50 |
Modeling blood flow - FloWorks | mcneelyd | FloEFD, FloWorks & FloTHERM | 2 | June 15, 2009 12:53 |
FLUENT BLOOD FLOW RATE | Christoforos | FLUENT | 0 | September 18, 2008 10:08 |
3D pulsatile blood flow UDF | Michal | Main CFD Forum | 0 | February 25, 2005 07:18 |
Fluent blood flow BC | Michal | Main CFD Forum | 3 | February 17, 2005 03:17 |
