from single passage to full annulus
Old   May 4, 2011, 10:16
Default from single passage to full annulus
Domenico
c120613 is on a distinguished road
Hi All,
I. doing calculations of a single passage of Rotor 67 and afterwards for some reason I need to have a result file .res which contains the full annulus solution. Is there anyhow to transform the single passage solution obtained with CFX to the full annulus?
In this way I should get an initial file where the solution will be periodic.
Thank you in advance
c120613 is offline   Reply With Quote
Single annulus concentric cylinder Satya prakash Main CFD Forum 0 February 3, 2011 00:40
[TGrid] Inlet passage in turbogrid. soldimix15 ANSYS Meshing & Geometry 0 September 5, 2010 11:34
Simulation of a single passage and volute Suzzn CFX 1 January 5, 2010 07:05
How to export single variable of a single surface? zeitistgeld CFX 6 September 26, 2009 06:37
P4 1.5 or Dual P3 800EB on Gibabyte board Danial FLUENT 4 September 12, 2001 11:44
