May 10, 2011, 06:21 |
Calculate natural frequency
omid
Rep Power: 15 |
Hi all
I have a rigid sphere that jointed with elastic rod. Diameter of sphere is 20cm and the rod have 50cm length an 1cm diameter. The sphere is submerged. How can i calculate the natural frequency of this system? Best regards. |
May 10, 2011, 09:00 |
Rep Power: 21 |
Use a Modal analysis in Workbench. The submerged regions will need a layer of acoustic elements added to account for the fluid. This approach neglects viscous effects. I would contact ANSYS support for the details.
May 11, 2011, 04:59 |
omid
Rep Power: 15 |
Thanks stumpy
I use it, but in Modal analysis i can't define any properties of fluid, i think submergence will affect the natural frequency of system, How can i do this? Best regards |
May 11, 2011, 06:39 |
Rep Power: 143 |
If viscosity will affect the modal frequencies then I think you will have to do it as a normal 3D simulation. It will be a long simulation. Only do it this way when you are completely sure modal analysis is inadequate as that will be so much easier.
May 13, 2011, 05:08 |
omid
Rep Power: 15 |
Thanks ghorrocks
How can i do this 3D simulation? |
May 13, 2011, 07:06 |
Rep Power: 143 |
Do the CFX tutorials and all will become clear.
May 13, 2011, 09:47 |
Rep Power: 21 |
There some details on the modal approach here:
http://www.idac.co.uk/enews/articles..._Acoustics.pdf You would have to use a Command Snippet to define the FLUID30 elements, so you would need to be familiar with the APDL language and/or get support to help. You still need to determine is viscous effects are important. For low velocities the virtual mass would be much more important, so the modal approach should give good results. |
Can Fluent find natural frequency? | Ken | FLUENT | 5 | September 23, 2014 20:40 |
natural frequency | Al Mazdeh | CFX | 0 | March 19, 2008 09:55 |
Natural gas combustion | Newbie | Main CFD Forum | 7 | May 22, 2004 04:00 |
Natural gas combustion | Newbie | FLUENT | 1 | May 17, 2004 11:00 |
