May 5, 2011, 22:35 |
Turbulence Model for PV Analysis
What would be a suitable turbulence model for analysis of Personalised ventilation systems? There will be a jet blown onto a seated human manikin and there'll definitely be boundary layer interaction.
We tried K-e and SST on a validation model of two impingement jets but the velocity decay in the middle region was around 40% of the experimental data. |
May 6, 2011, 02:21 |
Rep Power: 143 |
Did you you do the necessary accuracy check to make sure your validation model was accurate - mesh size, time step, convergence, other physics?
There has been a lot of research done on decay of a turbulent jet. If you dig up the literature you should be able to find the best turbulence model to get the jet decay accurate. |
May 6, 2011, 03:58 |
well, it converged to 1e-4 and using auto timestep and the meshing is an ordered grid whenever possible.
But you're right. I'll check out some literature. |
May 6, 2011, 08:15 |
Rep Power: 143 |
Looks like you need to do some validation of your model before you claim the turbulence model is inaccurate; Have a look at the tips here and in the CFX documentation.
http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F |
Adding a Turbulence Model | doug | OpenFOAM Running, Solving & CFD | 11 | May 21, 2018 13:54 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 10:26 |
turbulence analysis for naca0012 at Re=10,000 | lalit kumar | FLUENT | 1 | March 17, 2010 11:02 |
question about turbulence model selection and sensitivity | karananand | Main CFD Forum | 1 | February 26, 2010 04:41 |
v2-f turbulence model in CFX? | flga | CFX | 14 | November 23, 2006 06:12 |
