Error msg: In Analysis 'Flow Analysis 1': No domains have been defined. |
May 31, 2011, 07:03 |
Shui Pei
It worked in the past but one day the cfx gave me the messege:
In Analysis 'Flow Analysis 1': No domains have been defined. and stops reading my mesh file. Some one knows whats happening? I make a sphere and a box in the workbench, and make the mesh by sizing to the box and refining to the sphere then generate the mesh and save. when I open the setup, the error message appears. |
May 31, 2011, 08:25 |
Rep Power: 143 |
Looks pretty obvious to me - no domains are defined. Go back to CFX-Pre and define a domain.
May 31, 2011, 08:53 |
Shui Pei
May 31, 2011, 09:28 |
Christa
Import the mesh then right-click on Flow Analysis 1 and choose insert domain, give the new domain a name (preferably NOT domain 1, I usually choose the type of fluid I'm simulating, such as water) and then define BODY, or whatever name your volume has as your desired domain.
Sometimes these things may need re-defining, even though the same stuff has worked before. If your mesh won't be imported, even though the same mesh file used to work before then I'm sorry I cannot help, but looking into the mesh file, instead of the .cfx file may have your answer. Sometimes re-doing the geometry and mesh is the tedious but fastest way round the problem. Hope this helps. |
July 29, 2012, 11:39 |
if u are german -> this could help:
keine umlaute(ä, ö, ü) verwenden - auch nicht im Projektnamen |
July 31, 2012, 03:17 |
Addendum to what bratzinger said...not only do not use ä,ö,ü in the projectname...BUT do NOT use ANY special Signs in the WHOLE Path!
I had similar problems when I wanted to open a file located in smth. like: C:/CFX/Projects/Gebäude/Setup/Files/Pre/ and it gave me a similar error just because I had a Folder "Gebäude" containing the folders where my files are stored. I think this is valid also for all other language specific symbols or symbols like %, & and so on....Therefore I now name my files and folders only with standard alphabet and "_" as a separator/space. Because when I use " " (blanks) as space I get problems on unix/linux machines. |
September 10, 2012, 08:08 |
long PATH
Heinz Mutzner
in MS-Windows this seems to happen too, when the path to the file is very long
October 29, 2020, 04:28 |
Kourosh
Hi very body
I have this problem when I was imported the mesh Could you please guide me? thanks |
October 29, 2020, 04:41 |
Rep Power: 143 |
It means what is says, you have not defined any domains, and that is probably because you have no 3d mesh regions in your mesh. Make sure your mesh is CFX compliant, with one or more 3d regions, with each 3d region bounded by surface meshes on the outer faces.
October 11, 2022, 22:00 |
#10 | |
Aero_Cats!
Rep Power: 4 |
Try to open a new CFX Pre outside of/ without the workbench and import your mesh which was created from your workbench. I don't know what exactly happening but sometimes it works |
Preocedure for thermal flow analysis in fluent | sri0114 | Main CFD Forum | 0 | September 13, 2010 06:03 |
Compressible flow analysis | Sonu | Siemens | 3 | December 5, 2007 07:25 |
User defined function of mass flow rate | Eric | FLUENT | 1 | April 22, 2005 18:15 |
Coolant flow analysis - IC engine | Frank | FLUENT | 2 | May 19, 2002 15:59 |
Flow visualization vs. Calculated flow patterns | Francisco Saldarriaga | Main CFD Forum | 1 | August 2, 1999 23:18 |
