July 10, 2011, 00:35 |
Heat Transfer Between two Plates
Neil Heilemann
Rep Power: 15 |
I have two circular plates in contact with one another, rotating at the same speed, inside an air enclosure. I have set a solid to solid interface on the inside surface of each plate. I have also added a heat flux on one plate which changes the temperature of the same plate but not the other. I have left the frame change to None, the pitch change at None and Mesh Connection at GGI. Is there something I have missed in this interface?
July 10, 2011, 06:34 |
Rep Power: 143 |
If it works properly, you have not missed anything. If it does not work you probably have.
Heat transfer coefficient - what is waht | Stan | FLUENT | 28 | December 29, 2021 16:29 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
