Time Step and CEL expressions for Mesh Deformation |
July 1, 2011, 04:10 |
Richard Barrett
I am relatively new to CFX and I was just wondering if anyone could help me with a few problems that I have been having with a mesh deformation problem. I am modelling the compression of a piston within a cylinder. The actual geometry consists of two pistons within one cylinder, so there is a line of symmetry at mid chamber location. My model is also axisymmetric. The problem that I am having is that the simulation deformation is over predicting the applied displacement and I was wondering if there is an issue with (i) my CEL expressions or (ii) my time step. (i) The CEL expressions that I am using are ('WeightFunction' is a linear weighting function and 'Li' is the total length of the compression chamber): Disp = sDisp*WeightFunction Li = 0.178 [m] WeightFunction = 1-((z-sDisp)/(Li-sDisp)) sDisp = velCV*t velCV = 8 [m/s] (ii) The time step that I am using is 5.2e-4 s for a total compression time of 16.6 ms. Any help with this issue is greatly appreciated. |
July 2, 2011, 06:50 |
Rep Power: 143 |
You seem to be describing a strange motion. Doesn't your function describe a displacement proportional to z height? That means the piston will pivot, not slide.
The best way to debug mesh motion stuff is to do a test run with all the solvers turned off using the expert parameters, and saving a result file (including the mesh!) every time step. Then you can quickly run the mesh motion and check you are getting the motion you intend. |
July 4, 2011, 09:16 |
Rep Power: 21 |
There might be a problem with your weighting function here. Instead of using sDisp in WeightFunction use a callback to get the piston position, e.g areaAve(zGlobal)@movingend.
The callback is lagged to the previous timestep, but sDisp is not, which may be causing the unexpected behaviour. |
July 6, 2011, 10:13 |
Richard Barrett
The issue was related to sDisp in the weighting function. I have now replaced this with a function based on t-tStep and the model is deforming as desired. Thanks a million for your help.
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
Cel expressions for trasient problem | Jervds | CFX | 0 | March 4, 2008 10:03 |
error using combination of step function | xujjun | CFX | 1 | January 15, 2008 16:46 |
CEL using different time step for different domain | new@cfx | CFX | 3 | September 30, 2005 08:03 |
How does STEP function work in CEL setup in CFX5.5 | joseph | CFX | 1 | April 5, 2002 23:06 |
