July 2, 2011, 07:59 |
how to use non-uniform source
ibrahim
hi guys
i have a project contain a non-uniform source PROBLEM DESCRIPTION there is a receiver which absorbs heat flux (W/m^2). the heat flux in the surface of the receiver is non-uniform. I have the heat flux data as X,Y,Heat_Flux. is it possible to insert this data to ansys cfx? i try [Hot_Point] but the problem with this function. i cant enter the value as (W/m^2) NOTE: the non-uniform heat flux should stay static all the run_time (doesn't change with time) I hope can anyone could help me |
July 3, 2011, 06:57 |
Rep Power: 143 |
You might be able to use a 3D interpolation function. Just define the Z coordinate to be a dummy value.
July 3, 2011, 16:33 |
ibrahim
I am going to try it. Thank you
cfx |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
Need help with boundary conditions: open to atmosphere | Wolle | OpenFOAM | 2 | April 11, 2011 07:32 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
RasInterFoam STRANGE RESULTS AT BOUNDARY | kumar2 | OpenFOAM Running, Solving & CFD | 8 | March 24, 2008 18:38 |
