CO2 condensor mass flow rate BC at inlet and oulet possible?
Old   August 17, 2011, 22:20
Smile CO2 condensor mass flow rate BC at inlet and oulet possible?
Chun Wheng
Boo85 is on a distinguished road
hello everyone
i have just started learning CFX so as to simulate a condensor for an CO2 air con system and would like to know if such a scenario is possible.
Basically i want to do a transient simulation (would be considered compressible viscous fluid flow), what is known is:
  • at the inlet of the condensor is the compressor, and the compressor will have a certain mass flowrate depending on the pressure at the condensor inlet and the pressure in the compressor chamber
  • the outlet of the condensor there is the expansion valve which will control the mass flow rate depending on the pressure at the condensor outlet and the expansion valve outlet.
As such i will need to the boundary conditions of the condensor inlet and outlet to be mass flow rates. Will this set of boundary conditions for the fluid flow be robust or suitable?
Thanks alot!
Boo85 is offline   Reply With Quote
boundary conditions, condensor, heat exchanger, mass flow rate bc
Problem with centrifugal pump calculation Michiel Main CFD Forum 2 June 17, 2012 21:32
Re: how to do this turbine blade passage flow nanl manish Fidelity CFD 1 November 2, 2006 23:01
How to fix an outlet flow rate ? 242VDM242 FLUENT 2 November 24, 2004 08:48
Problem on boundry of two phase flow youngan CFX 0 June 30, 2003 02:32
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
