August 18, 2011, 11:14 |
Check enough license to run
Rep Power: 16 |
Hello!
I'm running some cfx runs in a cluster by means of Script-driven SGE . Since we have limited license of Ansys CFX, I could obtain errors in the simulations when I finally reach to simulate (there's a queue). żIs it possible to check if there's enough licenses until run? I remember seeing some trick to this on internet but I can't find right now. Thanks in advanced |
August 18, 2011, 18:44 |
Rep Power: 143 |
We used to use PBS to manage our cluster and had to make manual changes to PBS to get it to queue based on available licenses. I suspect you will have to do the same - but that is a question for SGE, not this forum.
August 18, 2011, 19:12 |
Rep Power: 16 |
I didn't know that my question is related directly with the script for the batch-queuing system. I'm submitting it in a supercomputer unmanaged for me
I'll ask in the correct forum. Thank you. |
ansys, cfx, license, sge |
license error | CFDUSERIN | CFX | 6 | February 22, 2020 00:58 |
Windows 64-bit, Distributed Parallel Run Issues... | Erich | CFX | 3 | March 28, 2006 16:36 |
problems with LES run | Tim | CFX | 1 | February 27, 2006 07:28 |
Problem in license file installing | rakib | FLUENT | 0 | March 2, 2003 03:30 |
License server gives problems | Karl | FLUENT | 1 | November 27, 2002 05:14 |
