August 18, 2011, 19:27 |
variable porous resistance
sajad
Rep Power: 15 |
hi to all
is it possible to change porous resistance by time? i use a "CEL expression" in form of "if(t<0.08[s],20000[m^-1],100000[m^-2] *t)" but it gives me that the dimenssins are inconsistent.... what is the problem? best regards |
August 19, 2011, 00:47 |
Rep Power: 143 |
The units of your expression are inconsistent. Before 0.08s it evaluates to 20000[m^-1], and after it evaluates to 100000[s m^2]. You need to fix your expression up and it should work fine.
August 19, 2011, 05:04 |
sajad
Rep Power: 15 |
hi.
your right it works.thanks i have another quastion.i define an "AV" by name of "cvr" then i give value of "20000[m^-1]" then i set the resistance of porous domain by expression and equal to "cvr",i iterate it it gives me q1 which is flowrate.then i set the value of "cvr" equal to "cvr" instead of "20000".actually they are equal. but when i run it fives me another q2. im really confused |
August 22, 2011, 21:36 |
Rep Power: 143 |
I do not understand your question. Please post the CCL of your case as an attachment.
Viscous resistance coefficients in porous medium | fpingqian | FLUENT | 50 | June 26, 2019 01:55 |
porous inertial resistance | Lukas | STAR-CCM+ | 21 | March 7, 2012 02:05 |
emag beta feature: charge density | charlotte | CFX | 4 | March 22, 2011 09:14 |
error in COMSOL:'ERROR:6164 Duplicate Variable' | bhushas | COMSOL | 1 | May 30, 2008 04:35 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
