August 20, 2011, 10:59 |
Question from help of CFX
Alireza Safikhani
Hi friends,
In the help of CFX at the Gas-Solid modeling part is stated that water should be selected as continuous fluid and sand should be selected as " Dispersed Fluid " however sand is solid and not fluid , what is the reason ? should we really select sand as a fluid ? regards |
August 20, 2011, 14:28 |
Mauricio Labarca
I'd model it as dispersed solid. You'll have to define the density and properties of the sand material you're going to use. I believe There's actually a tutorial of a dispersed solid and a continuous fluid around it i think.
August 20, 2011, 15:28 |
Alireza Safikhani
Thank you very much so you think it is wrong ? and it should be dispersed solid ?
August 20, 2011, 20:28 |
#4 | |
Mauricio Labarca
It's not technically wrong for a specific case, check this out from the documentation on cfx's multiphase modelling :
CFX pressure in Simulations problem | nasdak | CFX | 1 | April 14, 2010 13:22 |
CFX Post question - creating a reference vector | Martin | CFX | 2 | February 16, 2009 23:13 |
One question about the cfx 5 best practices | John | CFX | 3 | August 18, 2005 18:39 |
Question about the shock wave in CFX software | nucharin | Main CFD Forum | 1 | January 25, 2005 08:26 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
