Lift of fanwing
Old   September 16, 2011, 23:29
Default Lift of fanwing
Antoni Alexander
zkdkeen is on a distinguished road
Hello everyone!
I am simulating flow around fanwing as I posted several days before. After doing and adusting as Mr.Gorrocks suggested, the case successfully run and yeilds some results with fine velocity filed stucture as some article, but the Lift is much less than the same case motioned in the article. Say, with 6.812m/s in flow velocity, 1480 rpm fan rotation angle velocity, zero AoA and same geomety, the aritcle presents CL is about 8 (Q depending on in flow vel and S depending on whole wing aera), but my calculationg results CL as about 2.
The case in pre cfx I configured is general type, inner domain rotating, outter stationary, transient simulating, TRS interface, and sst turb model. And the grid is unstructured with 70,000 and 210,000 elements as coarsen and refined mesh.
So, my question is why the CL is so small? How to config my parameters in pre cfx to improve it? Any suggestion from any body will be highly appreciated!
Regards
keen
zkdkeen is offline   Reply With Quote
Old   September 17, 2011, 07:06
http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Old   September 19, 2011, 00:51
Antoni Alexander
Originally Posted by ghorrocks View Post
Oh, I see. I will follow the steps from the FAQ suggestion.
By the way, as to my case, the interface is a whole 360 degree circle between the wing and blades, so should I set the "pitch change" option to "None" or "Automatic"?
Old   September 19, 2011, 06:13
It does not matter. Both will not apply a pitch change.
Old   September 19, 2011, 13:18
Antoni Alexander
Got it! Thanks a lot! Mr. Ghorrocks
Lift distribution PB4 STAR-CCM+ 6 May 31, 2016 09:46
Lift coefficient in Eulerian multiphase model hennas FLUENT 1 July 4, 2011 16:50
Vortex Lattice Method: Calculating lift using circulation from vortex ring elements black&gold Main CFD Forum 11 June 26, 2011 23:51
Thin foil analsis (sail) - Lift Coeff Problem Kelvin CFX 3 December 22, 2008 16:22
Lift force or coefficient of lift Rola FLUENT 1 November 12, 2006 13:29
