Help in porosity for knitted fabric??? Linear or Quadratic resistance coeff |
September 15, 2011, 15:50 |
For knitted fabric having porosity of 30 and 50% similar to these photos Any suggesions of resonable values for Linear or Quadratic resistance coefficients? or permeability I need these values to define the porous material. I have spent considerable time searching for any useful literature for this issue. What is the range of values you expect would be appropriate for such fabric? For example: Quadratic resistance coefficients = 300 kg/m^4? Is it possible to calculate these values? I have gone through almost all threads regarding above parameters in this forum, I have been in this link too: http://www.cfd-online.com/Wiki/Fluen...e_drop_data.3F but the problem is that I don't have and can't perform experiment to obtain the required data. Could obtaining the loss coefficient K_loss and head loss be of any help? using this link http://www.thermal-wizard.com/tmwiz/ Regards |
September 15, 2011, 18:57 |
Rep Power: 143 |
You can estimate the resistance of a single isolated cylinder quite accurately, the drag of a cylinder is well known. If you search the literature you can probably find the drag/resistance of a bank of cylinders. You should be able to define a resistance coefficient from this.
September 16, 2011, 01:29 |
Thanks for your response ghorrocks
Is this what you are meaning by isolated cylinder (second and last objects) http://www.centennialofflight.gov/es...nts/TH12G8.htm found through this: http://www.centennialofflight.gov/es...ients/TH12.htm From Wikipedia I found this http://upload.wikimedia.org/wikipedi...4ilf1l.svg.png http://en.wikipedia.org/wiki/Drag_coefficient But which resistance is defined through the drag coefficient and how? Also, the knitted fabric is very thin, would that effect the cylinder assumption? Regards |
September 16, 2011, 06:36 |
#4 | |||
Rep Power: 143 |
But the drag of an array of cylinders next to each other is different to an isolated cylinder. You will have to take this into account. |
September 16, 2011, 09:17 |
#5 | ||
Thanks again dear ghorrocks
What i'm trying to do is to examine the effect of the fabric porosity on blowing air wind (So it is an open area not pipe for instance) I found the following link that provides a way to determine the resistance loss coefficient in (m^-1) (Is it enough to define the porosity of the fabric accurate enough?) http://jullio.pe.kr/fluent6.1/help/html/ug/node236.htm It is located under this title: Quote:
http://www.thermal-wizard.com/tmwiz/...ns/screens.htm Then continue with above approach? Quote:
Regards |
September 16, 2011, 09:28 |
#6 | |
Regarding the drag force, how can I use it to obtain the pressure drop, or head loss coefficient? any helpful equation? Sorry for the "shallow" questions but i'm structural engineer and lots of what I learned in fluid has vanished |
September 17, 2011, 07:15 |
#7 | ||
Rep Power: 143 |
September 17, 2011, 09:32 |
Many thanks dear ghorrocks
I appreciate your great help. Just want to make sure about one correlation I found during my search: loss coefficient = (1-porosity)*(drag coefficient) Best regards |
September 18, 2011, 07:42 |
Rep Power: 143 |
I have no idea about that. It does not seem to be applicable to the CFX approach as CFX does not use a loss coefficient of that form.
September 18, 2011, 15:27 |
I see,
I found it in this publication http://journals.tdl.org/ICCE/article/viewFile/4173/3854 equation 8 in 3rd page. When I used it with the assumption of cylinder having Cd=0.8-1.2 it gave reasonable results, although it may not be accurate or even correct! Best regards |
September 18, 2011, 18:26 |
#11 |
Rep Power: 143 |
Again, I do not have time to read your link.
But it appears that they are simple grossing up the individual cylinder drag to the local porosity. This sounds like a very approximate (ie not very acurate) approach to me as it does not take into account proximity effects. But if you have nothing better and do not need very accurate results then you could use it anyway. |
September 19, 2011, 05:11 |
#12 |
Anton Lyaskin
There is an empirical formula for meshes, which can also be used for fabric, I guess:
delta_P/(0,5*rho*V^2)=1,62*(1,3*(1-f)+(1/f-1)^2), where f is porosity |
September 21, 2011, 14:55 |
#13 |
Thanks A_Lyaskin for the formula, do you have a reference?
Best regards |
September 22, 2011, 11:43 |
#14 |
Anton Lyaskin
It's from "Handbook of Hydraulic Resistance" by Idelchik. There is a chapter about grids and meshes and etc. The formula is for wattled mesh.
Quadratic resistance Coefficient | Ramana | CFX | 4 | November 26, 2012 16:25 |
Quadratic Resistance Coefficient when energy source added. | JoFFe | CFX | 3 | October 27, 2010 08:42 |
solution diverges when linear upwind interpolation scheme is used | subash | OpenFOAM | 0 | May 29, 2010 01:23 |
Quadratic Resistance Coefficient | Ramana | CFX | 0 | January 2, 2006 03:43 |
quadratic resistance co-efficient | praveen rajaperumal | CFX | 2 | May 18, 2004 17:16 |
