Import new mesh on specified areas
Like Tree1Likes
  • 1 Post By Doginal
Old   November 4, 2011, 14:31
Default Import new mesh on specified areas
anonymous
Doginal is on a distinguished road
I have been working to create a simulation with a moving mesh that moves quite a large distance. Currently this is the break down of my simulation
Simulation begins
Interruption control when min orthogonal angle reached
Remesh configuration
- User defined
- Its kinda funny how it works but long story short, when remesh kicks in, it opens my workbench project that contains the geometry and mesh. I change a parameter defining the translation so far update the files save it and close. When work bench closes it reads the new mesh file (created by workbench) interpolates values and continues the simulation.
This may repeat as many times as needed until the simulation has finished.
What i would like to do is only remesh part of the full domain. As it stands there is an inner and an outer domain. The inner domain's mesh does not deform so to reduce computational time and errors due to interpolation, i would like to only remesh the outer domain.
There is a setting in the remesh configuration for "Location" however even when i only specify the outer domain the full mesh is replaced. Does anyone know how to fix this.
If your confused by my issue or have any questions regarding set up please just ask
Thank You,
DM
Doginal is offline   Reply With Quote
Old   November 14, 2011, 12:55
anonymous
bumping this topic up. I'm still having issues with this. Any info would be great
Old   November 19, 2011, 13:17
rahpoo
rahpooye313@yahoo.com is on a distinguished road
Simulation begins
- User defined
Thank You,
DM
I can't export Geometrical Parameters (that i want to modify my original geometry) to new workbench for regenerate mesh or REMESH.
Please help me and if you can, Email a sample Remesh project to my Yahoo mail.
(rahpooye313@yahoo.com)
rahpooye313@yahoo.com is offline   Reply With Quote
Old   July 15, 2012, 11:29
Darren Leong
Darren Leong is on a distinguished road
Hi Doginal,
I'm working on the AMP remeshing approach too n i would say the biggest snag is the interpolation error. I've not had any success with reducing it significantly, except by isolating it by reducing the timestep so that the results recover within a smaller simulation time window or blowing up the coefficient loop no., both which are extremely expensive workarounds for the problem.
You can reduce the meshing time by sub-dividing any curved surfaces on your body. But for complex geometries or when working with fine mesh of 2million elements above, the time for interpolation error to recover is anywhere from 10 to 100 times longer. Thus I wouldn't worry about the remeshing time.
Darren Leong is offline   Reply With Quote
Mesh and geometry import in cfx-pre Francesco CFX 7 May 30, 2012 08:04
Unable to import mesh on the CFX-Pre jarrai CFX 1 December 20, 2010 07:05
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Import ICEM Mesh to Fluent Fluent Beginner FLUENT 5 June 23, 2004 00:27
