Axial compressor map
Old   December 6, 2011, 06:10
Default Axial compressor map
Oleg
olegmang is on a distinguished road
Hi guys! Its me again. Still practicing in axial compressor calculation by calculating NASA 37 stage. The problem that I faced with is compressor map calculation. I tried to compare data from NASA report (TP-1659) with clalculation in CFX. Calculation was done in 3 steps for coarse (50000 elements) and fine meshes (900000 elements):
1) Points enclosed with red (see attached). I increased static pressure ratio step by step and everytihg was fine (more or less). k-e turbulence model was used on this step. But with this settings i couldnt reach desired pressure ratio (calculation was keeping to fall apart - MFR converged to 0).
2) Then i switched to SST model and it helped to calculate higher pressure ratios (see points enclosed with blue). But when it get to the point where the MFR ought to decrease (at least i think so) it become to fall apart again (MFR converges to 0).
3) Then i decided to change boundary conditions: MFR and total temperature at inlet and static pressure at oulet. Calculated 3 points with different outlet pressure (points enclosed with pink). And confused completely because pressure ratio depend on the pressure i set. Therefore i could choose outlet static pressure to fit experimental point. But i think it not qiute right because what should i do if i didnt have experimental map and wanted to create it?
What have i done wrong?
Maybe someone could give me algorithm of compressor map calculating in CFX or at least some tips
olegmang is offline   Reply With Quote
Old   December 6, 2011, 14:29
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
you are simulating with 14000 elements only? or atleast for the map shown here
Far is offline   Reply With Quote
Old   December 6, 2011, 18:43
Two comments:
1) There is a rotating machinery best practises guide in the CFX documentation. Have you read it?
2) For general accuracy issues see this FAQ: http://www.cfd-online.com/Wiki/Ansys..._inaccurate.3F
Old   December 7, 2011, 04:27
Oleg
As i mentioned before i calculated 2 cases with coarse (14000 elements) and fine (879616 elements) meshes. Its just on this map i showed curve for coarse mesh. For fine mesh curve looks even worse. So i decided not to show it (shy of my inexperience ).
Old   December 7, 2011, 04:45
Oleg
Originally Posted by ghorrocks View Post
Two comments:
Yes, i have read best practice guide and i read that post too. But as you can see unfortunately it didnt helped me. Please forgive me if i missed something. This is the reason why i post this thread. I wanted to ask people who are more experienced than i am what is wrong in my calculation (mesh, boundary conditions or something else)?
Old   December 7, 2011, 08:09
Far
Sijal
It is meaningless to have such a coarse mesh. Atleast try 200000 elements.
Old   December 7, 2011, 10:19
Oleg
I wrote you that i also used fine mesh - 879616 elements in stator and rotor, but it crashes as i reach total pressure ratio 1.7.
Old   December 7, 2011, 17:25
Your curve looks very wrong. Something is seriously wrong in your setup.
Can you post some images of what you are modeling and the CCL?
Old   December 8, 2011, 04:27
Oleg
Of course. I've attached the CCL file and the screenshot of CFX Pre window with the mesh. I couldnt attach the CCL file so i've added .doc to its extension. If I should do something else to attach it in the right way please tell.
Old   December 8, 2011, 05:25
D.B
DB
D.B is on a distinguished road
I found a small doubt in your CCl , correct me if I am wrong.
I see there is no counter rotating wall B. C. applied to your hub and casing in the rotor region. Have you not given any tip gap to rotor ? and is the hub rotating as well. Rotor tip gap have huge effect on losses and flow separation at the tips especially if they are given zero. A slight tip gap as compared to zero has huge effect on the performance. Check the tip gap
-D.B
D.B is offline   Reply With Quote
Old   December 8, 2011, 05:37
Also you have viscous work turned on. This almost certainly is insignificant but may add to simulation time and possibly instability. Turn it off.
Can you show some images of post processing of the flow?
Old   December 8, 2011, 07:31
Oleg
Sure. If you need something else please ask. Also i've noticed that there are some strange lines in outlet domain. But i'm not sure what does it mean.
Old   December 8, 2011, 12:10
Oleg
Originally Posted by D.B View Post
You're right. I've decided to calculate without radial clearance to exclude it effect (because i thought it would calculate more stable).
Old   December 8, 2011, 12:19
Oleg
The main problem is that i cant get right shape of performance curve (i'm not even dreaming about matching the experimental data). I thought that maybe i used some wrong boundary condition or or maybe there is something completely wrong with model settings. Or everything seems OK in calculation settings and i should look for a problem in a mesh?
PS. Sorry for bothering you guys with my stupid questions but my professor wants me to do this and i'm stuck
Old   December 8, 2011, 12:26
Far
Sijal
Try this
time scale factor = 1
Reference pressure = 0
Use average static pressure boundary condition at outlet
What is the maximum yplus in domain?
Old   December 8, 2011, 12:43
Far
Sijal
pls attach residual plots
Old   December 8, 2011, 16:26
Your simulation shows a separation. This will change the result substantially. Is it real? Separations are very sensitive to mesh, turbulence model and upstream conditions, and they cause major effects to the end result.
Old   December 9, 2011, 08:23
Far
Sijal
This is requirtment of your professor to ask stupid questions? Just kidding
Old   December 11, 2011, 02:53
Far
Sijal
The separation at hub is present in rotor 37 by design. There is huge literature on this aspect of rotor 37.
What I am not understanding is that " Why compressor map has jumps from one point to another point. Looks like choked flow after two to three operation points"
Old   December 11, 2011, 18:01
Ok, if this design has separations by design then the presence or not, and the size of the separation will have large effects on the result. And when the separation reaches critical points (eg is long enough to reach the full blade chord) it will cause jumps in the pump curve.
I suspect accurate modelling of this separation is the key for this model.
axial and z-velocity difference? user0314 FLUENT 1 May 27, 2016 12:30
how to plot out circumferentially mass averaged axial velocity in a rotor? wildli FLUENT 0 July 17, 2010 15:54
Transient axial rotor/stator convergence issue? Nicola Viscanti CFX 3 March 17, 2010 04:15
axial and azimuthally averaged profiles student CFX 0 February 28, 2006 04:20
About the design of axial fans HanCheolHeui Main CFD Forum 0 September 8, 1998 10:13
