December 16, 2011, 12:53 |
Increasing of total temperature
Roland Rakos
Rep Power: 17 |
I have a general 3D flow field. It contains a large region (a tube) where strong swirling zone occurs. In this zones the total temperature always becomes larger than the inlet total temperature which was defined as boundary condition. The walls are adiabatic and free slip. I don’t understand this. How can the total temperature increase above the inlet total temperature if there is not heat input and friction at the walls. Is this because of the viscosity (internal friction) of material? Regards Roland |
December 16, 2011, 15:08 |
Rep Power: 143 |
Have you got viscous dissipation turned on? Yes, this could be one explanation.
Also if the simulation is not fully converged you could get this. Also inadequate mesh resolution could contribute. |
December 20, 2011, 11:04 |
Rep Power: 21 |
Is the total temperature locally above the inlet value or is it the massFlowAve(Total Temperature) on a slice plane through the tube? If it's just locally then that's allowed to happen physically. It's similar to a local rise in Total Pressure (see "Rise of Total Pressure in Frictional Flow" - http://adsabs.harvard.edu/abs/1995AIAAJ..33..772I)
March 29, 2018, 01:15 |
Bal Krishan
Rep Power: 8 |
What do you mean by inadequate mesh? and how it causes the temperature increase more than total
March 29, 2018, 03:08 |
Gert-Jan
Rep Power: 27 |
Overshoots have been there since man invented numerical methods. These overshoots can be persistent when your mesh has low quality.
Problem with zeroGradient wall BC for temperature - Total temperature loss | cboss | OpenFOAM | 12 | October 1, 2018 06:36 |
Tf is averaged by static or total temperature ?? | NPU_conanxie | Main CFD Forum | 0 | April 6, 2011 21:30 |
Bulk temperature Tf is obtained from total or static temperature? | NPU_conanxie | FLUENT | 0 | March 30, 2011 05:56 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 07:59 |
