November 21, 2009, 21:07 |
Help! CFX crash messege!
Hao feilin
Rep Power: 16 |
hi,
when i simu a 3-phase case, i encountered the messege at the start of CFX-solver, what does it means and i should do? who knowns? please, ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | Stopped in routine GET_GVAR |
November 22, 2009, 04:43 |
Rep Power: 143 |
It is a setup error. You have not described anything about what you are try to do so I cannot help you any more.
November 23, 2009, 07:04 |
#3 | |
Hao feilin
Rep Power: 16 |
I setup a liquid-gas-solid simulation in a tank with baffles, with two domainne(tank) is fliud and the other(baffles) is solid, and want to simu the separation results when the mixture flow through. what do you need for a clear judgement? |
November 23, 2009, 07:23 |
Pratik Mehta
Rep Power: 17 |
I also think that your case setup has gone wrong since this error often occured to me at times of multiphase multicomponent simulations . I would guess you fluid definition / material definition has to be seen correctly. kindly cross check the values and also the reference pressure & reference enthaply of the fluid best of luck |
November 23, 2009, 08:14 |
#5 | |
Hao feilin
Rep Power: 16 |
thanks! |
November 15, 2010, 07:39 |
the same error
jianzhao sun
I have a same error with you!when I simulation a multiphase(solid paticle and fluid)with external magnetic.The .def file I take it into my e-mail.
email:questionsss@126.com password:123456789 I hope you can download it and find the reason for me.please! Thank you very much,please! NOTE:This is my first time reply using english,if something is wrong,please forgive me, thanks! |
February 7, 2012, 08:22 |
similar problem
Reza
Rep Power: 14 |
hello, I face a similar problem. would you inform me that how you solve it finally?
thanks a lot |
Pros and Cons for CFX, CFdesign, COMSOL | Val | Main CFD Forum | 3 | June 10, 2011 02:20 |
Importing solutions in CFX. | Alphonso | CFX | 1 | August 1, 2008 14:01 |
CFX Solver : Sudden crash | Hervé | CFX | 2 | June 16, 2008 06:40 |
PhD using CFX | Rui | CFX | 9 | May 28, 2007 05:59 |
CFX 4.4 installation problem | Pandu Sattvika | CFX | 1 | December 1, 2001 04:07 |
