March 13, 2024, 07:35 |
Flammability limit
Meysam
Rep Power: 6 |
I simulate a Butan leckage in a room and I use Butan/Air as the material in domains with different mass fraction. I would like to know, how can I show in cfx Post the Flammability range of my gas. I know the Butan Flammability limit is between 1.6 to 8.4 % . Exactly I say I would like to know which parameter such as Mass Fraction, Molar Fraction, Mass Concentration and etc shows in an Isosurface the percentage of Flammability limit . regards, |
March 13, 2024, 08:06 |
Gert-Jan
Rep Power: 27 |
This depends on how the percentages for the Flammability limits are defined. Better look it up.
However, my first guess is that it would be volume percentage i.e. Molar fraction as long as ideal gas law is applicable. |
March 13, 2024, 09:43 |
#3 | |
Meysam
Rep Power: 6 |
I think the percentages are the volume percentage. So it means I can use the Molar fraction. Isnīt it? bests, |
March 13, 2024, 10:37 |
Erik
Rep Power: 23 |
Molar Fraction is equal to Volume Fraction for ideal gas, so for this purpose, they are the same. If you modeled the gases as ideal gases, they are the exact same. Flammability limits are normally listed as volume fraction, probably just because VolFrac is more commonly used than MolFrac. For non-ideal cases, it is likely the mole fraction is the true variable of interest, since this is chemistry. So listing them as volume fraction is the simplification, and valid since they are essentially the same except for very specific situations, like a gas near its critical point.
April 30, 2024, 02:53 |
#5 | |
Meysam
Rep Power: 6 |
I would like to be sure, when we talk about a range of Molar Fraction from 0 to 1 in Cfd-Post, It means from 0 to 100 percent of Volume fraction. Isnīt it? wishes, |
April 30, 2024, 04:00 |
Gert-Jan
Rep Power: 27 |
Yes. As long as they are ideal gasses, this is true. As an engineer, you can assume that this is the case at room temperature and atmospheric pressure.
As a scientist in chemical engineering, I have some remarks. At low molar fractions butane, you have almost pure air. This can be treated as ideal gas at STP. At high molar fractions, you have almost pure Butane. I'm not fully sure if 100% Butane can be treated as idaal gas. The Butane molecule is not too large and not too complicated. But there are two types of Butane, making it a possible mixture of two components. Then things might become tricky. Molecualr interactions might be ideal, may be not. I don't know if this is relevant for your case. I would say that in engineering applications around explosion limits, this is irrelevant. But you really need to find out yourself. |
What is the Packing Limit and Friction Packing Limit? | rezasalehi | FLUENT | 0 | October 13, 2018 15:37 |
how to increase "Newton Pressure Iteration Limit" | kus | CFX | 9 | April 21, 2013 01:54 |
Image size limit | Far | Site Help, Feedback & Discussions | 0 | January 13, 2013 10:45 |
Rich Flammability Limit | JohannV | FLUENT | 2 | August 25, 2010 23:12 |
How to limit a variable | ash | OpenFOAM Running, Solving & CFD | 1 | June 26, 2008 20:32 |
