Quantifying the swirl in CFX, Swirl Number/Swirl Angle
Old   March 15, 2012, 04:56
Default Quantifying the swirl in CFX, Swirl Number/Swirl Angle
Raja_Bhai
tauqirnawaz is on a distinguished road
[Note: It might be the case that this information has already been shared on the CFX forum but this is an effort to bring it under one thread.]
Quantifying swirl becomes very important in some situations where you would like to reduce it or even sometimes when requirement of design is to increase the swirl.
Swirl Number:
The degree of swirl in the flow can be quantified by the dimensionless parameter, Sn, known as the swirl number which is defined as the ratio of the axial flux of angular momentum to the axial flux of axial momentum:
To calculate in the CFX, create the following CEL expression;
Swirl Number [non dimensional] = areaInt(Density*sqrt(Velocity v*Velocity v)*sqrt((Velocity u*Velocity u)+(Velocity w*Velocity w))*sqrt((X*X)+(Z*Z)))@Plane 1/(maxVal(sqrt((X*X)+(Z*Z)))@Plane 1*areaInt(Density*Velocity v*Velocity v)@Plane 1)
Where
areaInt = Area Integral
sqrt = Square Root
Velocity v = Velocity in mean flow direction i.e. Y-axis in this case
Velocity u = Velocity in X-axis
Velocity w = Velocity in Z-axis
maxVal = Maximum Value
Y-axis is perpendicular to Plane 1, while X-axis and Z-axis are parallel to the Plane1 in this case.
For centrifugal pump impeller design it should be between 0.05-0.1 for good suction performance or 0.01 for excellent suction performance.
Swirl Angle:
This is again very important for specifying the blade angles in centrifugal pumps.
Use following CEL expression;
Swirl Angle[radians] = atan2(sqrt(Velocity u^2+Velocity w^2), sqrt(Velocity v^2))
Where
atan2 = arctangent
sqrt = Square Root
Then create a variable SwirlAngleVariable to calculate an area average over the plane, this would give you a value in degrees.
tauqirnawaz is offline   Reply With Quote
Old   March 15, 2012, 21:50
Safia
happy is on a distinguished road
Swirl Number:
Sn or Swirl number is defined as
Where
sqrt = Square Root
Swirl Angle:
Where
atan2 = arctangent
sqrt = Square Root
Hi Raja_Bhai.....
As I know that the results from cfx is in x,y,z coordiantion, and the velocity component into the above expression is in r, tetha, z coordiante. your expresion can make unaccurate estiamtion of swrling no.
You know some times the horizontal plane which include the two component of the velocity, (in r and theta direction or in x&z direction ( considering Z is vertical) is inclined with angule. so the unaccurate estiamtion can come from.
If any one has any knowledge about this issue, please share it with us.
Best Regards
happy is offline   Reply With Quote
Old   March 15, 2012, 22:59
Safia
Swirl Number:
Where
sqrt = Square Root
Swirl Angle:
Where
atan2 = arctangent
sqrt = Square Root
Hi again
does your celexpression is for the swirl coming from rotating configuration or even for the natural induced?
Regards
Old   March 16, 2012, 04:20
Raja_Bhai
Originally Posted by happy View Post
Hi again
Regards
Safia,
I normally use these expressions for the calculation of swirl at pump suction (i.e. stationery frame of reference), to adjust the blade angles. Never used them for the rotating frames.
Old   April 12, 2012, 04:03
igo
federico ghirelli
igo is on a distinguished road
it seems to me that the swirl number as defined above is not dimensionless.
igo is offline   Reply With Quote
Old   April 12, 2012, 07:52
Raja_Bhai
Did you check it in CFX or is it a guess?
Old   April 13, 2012, 05:05
igo
federico ghirelli
no I didn't check it in CFX, i just looked at the expression.
Probably the correct expression includes a r^2 in the integrand on top:
Old   April 13, 2012, 23:03
Default correct expression
Safia
yes, I agree with you I check with many references that r^2 instead of r. see Snegireve et al. (2004).
Regrads
Old   April 15, 2012, 18:24
Also be aware that there are different definitions of swirl. For internal combustion engines, swirl inside a combustion chamber is usually defined as the angular momentum of the gas divided by the angular momentum of the same gas if it was in solid body rotation at the crank angular velocity. This results in a unitless number as it is the ratioes of angular momentums.
Old   April 25, 2012, 06:10
Raja_Bhai
Agreed the correct equation is
areaInt(Density*(sqrt(X^2+Z^2))^2*sqrt(Velocity v^2)*sqrt((Velocity u^2)+(Velocity w^2))*sqrt(X^2+Z^2))@Plane 1/(maxVal(sqrt(X^2+Z^2))@Plane 1*areaInt(Density*(sqrt(X^2+Z^2))*Velocity v^2)@Plane 1*1 [m])
Any comments!
Old   April 25, 2012, 21:54
Talking questions
  #11
Safia
Any comments!
yes, where 1[m] comes from where you represent r as sqrt(X^2+Z^2)? as well as, I why you take square root of v^2 or u^2 instead of taking direct variable ( v or u)?
Old   April 26, 2012, 03:29
Raja_Bhai
You have to divide the equation by 1[m] to make it dimensionless because when you take max value of the radius; the output you get is dimensionless in CFX. If you do not divide by the unit 1[m], the value of Swirl Number that you get is in meters.
Secondly you take root of squares of velocities to get absolute values, otherwise you might get a negative swirl number.
Old   April 26, 2012, 06:22
Then why not use the abs() function?
Most definitions of swirl numbers can be positive or negative so you get the direction of the swirl. If you want the absolute swirl number then you should calculate it including sign, and take the abs value once at the end.
(sqrt(X^2+Z^2))^2
Why take the square root then square it again?
Your comment about units is puzzling. The equation seems to have the units cancelling giving a unitless number. If you have to put a divide by 1[m] at the end to get the correct units then you have a mistake in the CEL.
Old   April 26, 2012, 10:49
Raja_Bhai
Agree that abs() function would do the same thing. As regards square of radius, it comes from the formula quoted earlier and I have used sqrt(X^2+Z^2) to calculate radius. Also sqrt((Velocity u^2)+(Velocity w^2) to calculate radial velocity components.
Old   April 26, 2012, 18:45
That is obvious. So why write "(sqrt(X^2+Z^2))^2" when this obviously becomes (X^2+Z^2)?
But my key point is about the units - your formula is almost certainly wrong if you have to add a divide by 1[m] at the end to get the units to check out.
Old   April 27, 2012, 07:03
Raja_Bhai
Thank you Ghorrocks, please find the corrected formula below;
areaInt(Density*(X^2+Z^2)*sqrt(Velocity v^2)*sqrt((Velocity u^2)+(Velocity w^2)))@Plane 1/(maxVal(sqrt(X^2+Z^2))@Plane 1*areaInt(Density*(sqrt(X^2+Z^2))*Velocity v^2)@Plane 1)
Old   April 27, 2012, 20:00
Default to know the direction of swirling flow
  #17
Safia
As I read through fluid flow books, I learnt that the sign of vortisity (omiga) provides the researcers with the direction of swirling if it was anticlockwise or clockwise.
Old   April 28, 2012, 06:25
Raja_Bhai
So this means we can use Swirl Number to quantify the flow and Vortisity to predict the direction?
Old   April 28, 2012, 23:44
Safia
swirl no. use to know the strenght of swirling flow and yes the vorticity is useful to know swirling flow direction.
Old   April 30, 2012, 23:43
geno0624 is on a distinguished road
Mr Glen Horrocks, your comment above has confused me! I just read through a research paper titled "Swirl Control of Combustion Instabilities is a Gas Turbine Combustor" by C. Stone and and S. Menon - Proceedings of the Combustion Institute, Vol 29 / 2002, pg 155-160.
This paper calls out the exact (corrected) formula for swirl number that tariq wrote down in post# 10. Would this formula still be valid, given the alternate definition that you posted for swirl for a gas inside a combustion chamber??
I am a student and relatively new to CFD so please excuse my ignorance.
geno0624 is offline   Reply With Quote
angle of attack CFX Arj CFX 17 October 2, 2015 07:07
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 02:20
Proper output of angle of attack in CFX post Kevin CFX 3 October 18, 2006 12:18
Angle measurement in CFX sham CFX 0 September 2, 2006 00:26
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 04:07
