assign pressure initial condition on a flexible porous wall |
March 28, 2012, 23:11 |
Shashwat
Rep Power: 14 |
Dear friends
I am doing Transient analysis.The flow is in the z direction in a flexible porous pipe. model inlet condition : pressure(t), outlet: Mass flow rate I have data as shown below t=0s, p= 130mmHg t=0.1s , P= 135mmHg and so on. No other data I have. I need to set Global initial conditions on fluid domain and porous domain. I set the initial conditions in the fluid domain as shown below : static pressure> Option>Automatic value with value>Relative pressure = 130 mm Hg Is it correct? I set velocity U=0m/s, V=0m/s , W= 0.4m/s (for example) similarly I need to set initial conditions in the porous domain. Kindly help me to set the initial conditions. I set U=0 m/s , V=0m/s , W=0 m/s static pressure> Option>Automatic value with value>Relative pressure = ? Is the pressure is same as 130 mm Hg or 0 ? Kindly help me to proceed my simulations Thank you Regards Govind |
March 29, 2012, 05:49 |
Rep Power: 143 |
What mass flow do you have at the outlet?
March 30, 2012, 00:04 |
Shashwat
Rep Power: 14 |
March 30, 2012, 04:59 |
Rep Power: 143 |
So you have a constant flow rate leaving the domain with a variable pressure being applied? This sounds unusual. Is the fluid compressible or incompressible?
I have no idea what you are modelling so cannot comment on whether it is sensible or not - but so far it sounds strange. |
March 31, 2012, 10:14 |
#5 | |
Shashwat
Rep Power: 14 |
it is incompressible flow in a artery . it is an average flow in one cardiac cycle. |
March 31, 2012, 16:16 |
Rep Power: 143 |
In that case this is likely to be a FSI simulation.
Are you having any problems in running this? What is your question? |
April 1, 2012, 08:23 |
Shashwat
Rep Power: 14 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 04:13 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
AMG versus ICCG | msrinath80 | OpenFOAM Running, Solving & CFD | 2 | November 7, 2006 15:15 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
