Discretization schemes of Comsol stationary solver |
October 13, 2014, 09:10 |
Sami
I would like to ask you how can I see what are the discretization schemes that a Comsol solver uses. This information is of great importance for any numerical study but Comsol doesn't show this ! Thank you in advance. PS: references are welcome Mehrez |
January 17, 2016, 08:57 |
To display this section, click the Show button and select Discretization. It controls the
discretization (the element types used in the finite element formulation). From the Discretization of fluids list select the element order for the velocity components and the pressure: P1+P1 (the default), P2+P1, or P3+P2. ! P2+P1 means that second order discretization for velocity field and first order discretization for pressure |
January 17, 2016, 09:18 |
A new problem with discretization with comsol
i have another problem with discretization with comsol:
i use a SST scheme for a 3d geometry(sth like a tube with diameter of 30 mm and length of about 150 mm) every thing goes well for first order discretization type(P1+P1)and it converges up to 1e-5 with a relaxation factor about 0.5 BUT the problem begins when i want to solve the same problem with a second order discretization for the velocity field(P2+P1)! the software default discretization type is (P1+P1) and it has also mentioned that second order discretization for physics other than creeping flow will encounter with convergance problem and second order discretization will be suitable just for creeping flows. NOW i wanted to know whether a first order discretization will have enough accuracy or i have to deal the problem with second order discretization ??? Thanks in Advance! |
comsol, discretization, scheme, solver, study |
discretization schemes for Gradient | rayan24 | Fluent UDF and Scheme Programming | 1 | September 26, 2013 10:07 |
Grid Independence with discretization schemes | saisanthoshm88 | CFX | 19 | May 22, 2013 10:10 |
OpenCL linear solver for OpenFoam 1.7 (alpha) will come out very soon | qinmaple | OpenFOAM Announcements from Other Sources | 4 | August 10, 2012 11:00 |
Best solver for hydrulic valve cfd with Comsol? | Mr Matti Karvonen | COMSOL | 0 | July 3, 2008 05:56 |
Solver Selection with COMSOL | S. Gatzka | COMSOL | 1 | January 27, 2008 16:35 |
