September 22, 2017, 12:06 |
Simulation time parameters for IC engine
amin u3fi
I'm simulating dual-fuel engine and the engine speed is 900 rpm. I defined initial time step, Min time step, and max time step as 1e-5, 1e-8,1e-4 sec, respectively. So, Why these are not based on the crank angle? If I even put these numbers, around spray injection timing and combustion phasing, CONVERGE calculate each 0.03 crank angle which is very low and time-consuming. If I increase it I face some errors. So, what do you recommend for the time step? Mostly it should be around 0.1 or 0.25 for the spray and combustion phasing. |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
