February 24, 2018, 15:43 |
Animation in View options
Nitisha Ahuja
Rep Power: 11 |
hello, I am trying to run a IC engine simulation In CONVERGE. The problem, I am facing is I am having a hard time understanding the beginning stroke in Converge. What I mean is if I put 720 CAD as start time, and my piston is at BDC., what stroke will start immediately: like compression or suction? Also when I try to simulate the piston simulation along with valve simulation in the View options. I only see no interference , but dont see both the piston and valve motion. Can Converge do that? If no, how do I make sure what will my initial stroke be, and I can make sure my valve profiles are adjusted according to that?
February 26, 2018, 02:09 |
Tobias
Rep Power: 11 |
0 °CA is Firing TDC, which means 720°CA is the same. Just make sure all profiles and injection angles, ignition angle etc are related to 0° Firing TDC. You can start at whatever °CA you want, make sure to initialize with useful values. CONVERGE will move the piston and valves to correct position and then start the simulation. |
February 26, 2018, 09:40 |
Nitisha Ahuja
Rep Power: 11 |
Thanks a lot, for the information.
animation CFX | mat_cfd | CFX | 1 | May 26, 2013 21:47 |
modify animation view | nycera | FLUENT | 3 | February 25, 2009 14:45 |
CFX 11 Post, View options | Debabrata | CFX | 2 | June 16, 2008 04:28 |
Multiblock animation in Tecplot. | Simon | Tecplot | 4 | February 10, 2006 10:27 |
Animation query..newbie qn | derick | FLUENT | 2 | December 9, 2005 09:45 |
