January 19, 2021, 21:50 |
JOB ABORT invoked by rank 17
Lynn
Rep Power: 5 |
Hello everyone,
I am getting the same error again and again. The error message is as below: " JOB ABORT invoked by rank 17 ERROR: wrong boundary motion_type in calc_moving_vec boundary id = 15" What's the meaning of this error ? I have only 14 boundaries in my case. Then where this boundary id 15 came from? Please Help! Thanks. |
January 21, 2021, 14:51 |
#2 | |
Nitesh Attal
Rep Power: 8 |
Please share your boundary.in file so that we can take a closer look. |
January 21, 2021, 21:44 |
#3 | |
Lynn
Rep Power: 5 |
The boundary id of my case is from 2 to 14, but the error id is 15. The contents of boundary.in file are shown below. #!CONVERGE_VERSION=2.3.0 #======================= 13 # Number of boundaries defined #----------------------------------------------- 2 saoqixiang WALL FIXED Stationary roughness 0.0 0.5 velocity Law_of_wall 0.0 0.0 0.0 pressure Neumann 0.0 temperature Law_of_wall 304.1 species Neumann 0.0 passive Neumann 0.0 tke Neumann 0.0 eps Dirichlet 0.0 omega Dirichlet 0.0 region 2 #----------------------------------------------- 3 piston WALL MOVING Translating roughness 0.0 0.5 velocity Law_of_wall $ 0.0 pressure Neumann 0.0 temperature Law_of_wall 773.0 species Neumann 0.0 passive Neumann 0.0 tke Neumann 0.0 eps Dirichlet 0.0 omega Dirichlet 0.0 region 0 #----------------------------------------------- 4 ring WALL FIXED Stationary roughness 0.0 0.5 velocity Law_of_wall 0.0 0.0 0.0 pressure Neumann 0.0 temperature Law_of_wall 313.8 species Neumann 0.0 passive Neumann 0.0 tke Neumann 0.0 eps Dirichlet 0.0 omega Dirichlet 0.0 region 0 #----------------------------------------------- 5 liner WALL FIXED Stationary roughness 0.0 0.5 velocity Law_of_wall 0.0 0.0 0.0 pressure Neumann 0.0 temperature Law_of_wall 498.0 species Neumann 0.0 passive Neumann 0.0 tke Neumann 0.0 eps Dirichlet 0.0 omega Dirichlet 0.0 region 0 #----------------------------------------------- 6 saoqikou WALL FIXED Stationary roughness 0.0 0.5 velocity Law_of_wall 0.0 0.0 0.0 pressure Neumann 0.0 temperature Law_of_wall 313.8 species Neumann 0.0 passive Neumann 0.0 tke Neumann 0.0 eps Dirichlet 0.0 omega Dirichlet 0.0 region 2 #----------------------------------------------- 7 outflow OUTFLOW velocity Neumann 0.0 0.0 0.0 pressure Dirichlet 318300.0 0.0 temperature Neumann 0.0 species Neumann 0.0 passive Neumann 0.0 tke Neumann 0.0 eps Neumann 0.0 omega Neumann 0.0 temperature backflow Dirichlet 569.0 species backflow Dirichlet 4 N2 0.7382738 O2 0.119812 CO2 0.09350935 H2O 0.04840484 passive backflow Dirichlet 1 OUTPORT_EXHASUST 1.0 tke backflow Intensity 0.05 eps backflow Length_scale 0.02 omega backflow Length_scale 0.003 region 1 #----------------------------------------------- 8 export WALL FIXED Stationary roughness 0.0 0.5 velocity Law_of_wall 0.0 0.0 0.0 pressure Neumann 0.0 temperature Law_of_wall 391.0 species Neumann 0.0 passive Neumann 0.0 tke Neumann 0.0 eps Dirichlet 0.0 omega Dirichlet 0.0 region 1 #----------------------------------------------- 9 head WALL FIXED Stationary roughness 0.0 0.5 velocity Law_of_wall 0.0 0.0 0.0 pressure Neumann 0.0 temperature Law_of_wall 823.0 species Neumann 0.0 passive Neumann 0.0 tke Neumann 0.0 eps Dirichlet 0.0 omega Dirichlet 0.0 region 0 #----------------------------------------------- 10 valveangle WALL MOVING Translating roughness 0.0 0.5 velocity Law_of_wall "valve-75-115.in" 0.0 pressure Neumann 0.0 temperature Law_of_wall 823.0 species Neumann 0.0 passive Neumann 0.0 tke Neumann 0.0 eps Dirichlet 0.0 omega Dirichlet 0.0 region 1 #----------------------------------------------- 11 valvetop WALL MOVING Translating roughness 0.0 0.5 velocity Law_of_wall "valve-75-115.in" 0.0 pressure Neumann 0.0 temperature Law_of_wall 823.0 species Neumann 0.0 passive Neumann 0.0 tke Neumann 0.0 eps Dirichlet 0.0 omega Dirichlet 0.0 region 1 #----------------------------------------------- 12 valvebottom WALL MOVING Translating roughness 0.0 0.5 velocity Law_of_wall "valve-75-115.in" 0.0 pressure Neumann 0.0 temperature Law_of_wall 823.0 species Neumann 0.0 passive Neumann 0.0 tke Neumann 0.0 eps Dirichlet 0.0 omega Dirichlet 0.0 region 0 #----------------------------------------------- 13 pistonskirt WALL FIXED Stationary roughness 0.0 0.5 velocity Law_of_wall 0.0 0.0 0.0 pressure Neumann 0.0 temperature Law_of_wall 313.8 species Neumann 0.0 passive Neumann 0.0 tke Neumann 0.0 eps Dirichlet 0.0 omega Dirichlet 0.0 region 2 #----------------------------------------------- 14 inflow INFLOW velocity Neumann 0.0 0.0 0.0 pressure Dirichlet [342300.0] temperature Dirichlet 304.1 species Dirichlet 4 O2 0.2314 N2 0.7619 CO2 0.0002 H2O 0.0065 passive Dirichlet 1 FRESH 1.0 tke Intensity 0.05 eps Length_scale 0.03 omega Length_scale 0.003 region 2 |
January 25, 2021, 15:05 |
#4 | |
Nitesh Attal
Rep Power: 8 |
Looks like your disconnect triangles might be moving. Check your events and boundary motion. Check if valve is moving during a closed event (you would have to check your valve lift profile). |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 42 | May 7, 2024 23:17 |
JOB ABORT invoked by rank 0 | ankitraut27 | CONVERGE | 5 | January 20, 2021 21:39 |
Problem running in parralel | Val | OpenFOAM Running, Solving & CFD | 1 | June 12, 2014 02:47 |
OpenFOAM compile error | balkrishna | OpenFOAM Installation | 9 | June 17, 2011 03:53 |
Compiling OpenFOAM on hpc-fe.gbar.dtu.dk | kaergaard | OpenFOAM Installation | 1 | June 16, 2011 01:33 |
