February 9, 2023, 08:47 |
Intersection at a specific time step
Alireza Kakoee
Rep Power: 3 |
I don't know how much this question is relevant to this forum subject but it is relevant to converge studio. I have a problem in specific time step with intersection boundaries. " Intersection detected between boundary 2 and 2 near point (7.860669e-02 2.315171e-03 5.887143e-02) at time -1.276000e+02. " Would you please guide me how can I resolve that. Bests |
February 9, 2023, 08:58 |
Angela Wu
Rep Power: 3 |
Hi Alireza,
Can you provide a screenshot of the boundary 2 in Studio, and what kind of event you have set up for that boundary? Is the boundary moving? Thanks, Angela |
February 9, 2023, 09:11 |
Boundary 2 is liner
Alireza Kakoee
Rep Power: 3 |
Boundary 2 is liner and connected to piston and head. the intersection error is accrued after about -40 degree piston movement. Maybe there is something related to head position.
February 9, 2023, 09:16 |
Whole error message
Alireza Kakoee
Rep Power: 3 |
FATAL_ERROR: [3499] Intersecting geometry has caused an unrecoverable fault when cutting the geometry, please inspect the geometry at time -1.311749e+02.
Abort(1) on node 2 (rank 2 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 1) - process 2 |
February 9, 2023, 09:22 |
Angela Wu
Rep Power: 3 |
Please check the piston position by doing an animation in Studio in the View Options tab. There you can also check for triangle intersection in each step. Do an animation for a full engine cycle, and focus on the timing that CONVERGE is saying there's an intersecting geometry.
February 9, 2023, 09:36 |
No intersection error
Alireza Kakoee
Rep Power: 3 |
no intersection error in both diagnoses and animation check
February 9, 2023, 10:08 |
Angela Wu
Rep Power: 3 |
Hi Alireza,
Please send your case setup to support@convergecfd.com and we can take a look from there. Thanks, Angela |
February 9, 2023, 10:11 |
Thank you
Alireza Kakoee
Rep Power: 3 |
I am already in conversation with support
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 42 | May 7, 2024 23:17 |
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 18:28 |
Transient simulation not converging | skabilan | OpenFOAM Running, Solving & CFD | 14 | December 16, 2019 23:12 |
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores | puneet336 | OpenFOAM Running, Solving & CFD | 11 | April 7, 2019 00:58 |
