October 20, 2023, 11:22 |
Checkpoints for running Converge
Abdalrazik EssamAldin
Rep Power: 3 |
Hello all,
I am using an HPC at the university I'm attending where the maximum allowable wall time for calculation is 24 hrs. My simulations, indeed, need more than that, so the supporting team of the HPC facility informed me that I can use "checkpoints". This way I can run for 24 hours and pick up the slack from where it stopped with the next job submission. I went through the Converge manual and Getting-started manual, but I couldn't find anything similar. So, may I ask you, please, is this option available? And if so, I would be truly appreciative if you could guide me on how to do it. |
October 23, 2023, 02:28 |
Tobias
Rep Power: 11 |
That should be standard restart files.
You can specify crank angle or time based restart files (every 1h for example). May be a bit difficult to automate this. |
Can all solution methods converge? | Nawaf_Ar | FLUENT | 5 | September 6, 2022 07:56 |
Need help running CONVERGE for the first time | ad1314 | CONVERGE | 2 | May 25, 2021 15:40 |
Are simulations done in Converge 3.0 not possible to do in Converge 2.4? | EternalSeekerX | CONVERGE | 1 | March 29, 2021 07:10 |
Installed Converge on CentOS 7, converge solvers via command line work, gui doesn't? | EternalSeekerX | CONVERGE | 1 | December 2, 2020 10:15 |
tutorial guide of converge | Weiqiang Liu | CONVERGE | 4 | August 6, 2020 04:24 |
