Abdalla
Rep Power: 12 ![]() |
i have a LES motor flow simulation loaded in Ensight10. I already changed the "part element settings" to -Border- so i can view the hole surface of the fluid. Unfortunately the fluid looks like as a accumulation of Lego bricks as you can see in the Attachment. Is there a way to interpolate between the edges? If this helps, i do even have the original .stl (CAD-geometry file) including the surface where the fluid runs through. thank you Best regards, Abdalla forum.jpg |
LES Filtering: how are the small and large scales equations solved? | atmcfd | Main CFD Forum | 38 | March 14, 2016 14:52 |
Postprocessing of LES data in FLUENT | anee | FLUENT | 0 | September 27, 2011 01:10 |
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 11:35 |
Import Postprocessing VTK or Ensight Data | Fab | FLUENT | 1 | December 19, 2007 09:29 |
Some Questions about LES. | Bin Li | Main CFD Forum | 2 | February 20, 2004 09:58 |
