Home > Forums > Visualization & Post-Processing Software > EnSight
Calculating the wetted perimeter
Like Tree1Likes
  • 1 Post By Marina G
Old   April 13, 2015, 17:56
Question Calculating the wetted perimeter
Soroush
SH_P is on a distinguished road
How can I calculate the length of curves which bound a clip plane? Apparently, there is no built-in function for that. I figured that if I can extract the curve, I can use the IntegralLine function, but I don't know how to extract it!
Cheers,
Soroush
SH_P is offline   Reply With Quote
Old   April 14, 2015, 14:05
Marina G's Avatar
Marina Galvagni
Marina G is on a distinguished road
Hi Soroush,
You can extract the border of the clip as a new 1D part, and then use the Calculator function "Length", that returns the sum of all the lengths of 1D elements.
To extract the border of the clip, do the following. Change the representation of the clip part to be "Border" (select the part in the part list, then use the Part element settings icon at the top-right). Then, do Edit -> Parts -> Extract. This will create a new part that is only the current representation of the parent part (the clip). So, it will be composed of only 1D elements. Now you can apply Length to this extracted part.
Let me know if this is not what you were looking for, or if you have more questions.
Best Regards,
Marina Galvagni
CEI Software Support Engineer
SH_P likes this.
Marina G is offline   Reply With Quote
Questions on dynamicTopoFvMesh danvica OpenFOAM Running, Solving & CFD 80 April 16, 2019 16:58
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 20:47
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL AndoniBM OpenFOAM Running, Solving & CFD 2 March 25, 2015 18:44
Problems in calculating the fluid traction on the current structure frame in 3D models fw407 OpenFOAM Running, Solving & CFD 0 August 6, 2008 12:04
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
