October 8, 2017, 13:15 |
about graphics issue
Hiren Tala
Rep Power: 9 |
Hello
i want to drag CH4 in cutting mid plane of cylinder and want to see its flow, but problems of graphics arise, can anyone tell me the solution for that. thanks in advance. hiren tala123.png |
October 13, 2017, 15:30 |
Marina Galvagni
Rep Power: 12 |
The problem is that your machine doesn't have a graphics card that supports the drag&drop operations. Therefore, these operations are not available. As a solution, you can update to the newer version of EnSight - 10.2. This version contains some changes that will allow you to perform these operations even with a low end graphics card. Please note that, while very handy, these kind of operations are not necessary. You can reach the same result with other approaches. For example, right-click on the part(s) in the part list -> Color by -> Select variable, instead of drag&drop the variable onto the viewport. Best Regards, Marina Galvagni CEI Software Support Engineer |
Convergence issue in natural convection problem | chrisf90 | FLUENT | 5 | March 5, 2016 08:30 |
Strange issue while launching ANSYS workbench in CentOS 6.4 | Philip_C | ANSYS | 11 | August 29, 2013 06:44 |
CyclicAMI Issue In OpenFOAM 2.2.0 | prasant | OpenFOAM Running, Solving & CFD | 17 | March 16, 2013 02:00 |
Meshing related issue in Flow EFD | appu | FloEFD, FloWorks & FloTHERM | 1 | May 22, 2011 08:27 |
How to change and fix the size of graphics window? | Rob | FLUENT | 1 | February 7, 2003 10:15 |
