Home > Forums > Software User Forums > Fidelity CFD
wind gradient for sailing boat
Old   August 7, 2012, 20:57
Default wind gradient for sailing boat
laurentL
laurent98 is on a distinguished road
Hi all,
i'am working on sailing boat finemarine simulations and I would like to modeling the wind as close as possible of the reality, so with a velocity gradient, U function of altitude z .
I have read the Manuel, p207, but I would appreciate some help if anybody did this before, in particular the little fortran program.
Thank very much by advance LL
laurent98 is offline   Reply With Quote
Old   August 21, 2012, 04:54
Eloïse
Eloise is on a distinguished road
Hello Laurent,
I haven't done yet this kind of computations in Fine Marine, but you will need a background mesh with a vertical gradient in the cell size in order to model a velocity gradient. In order to make such a mesh in Hexpress, I got this guidelines from the support:
In a first project:
1) define a 1st domain (without the geometry you want to mesh) which has the exact same dimensions as the domain you would like to have at the end.
2) At initial mesh step, chose X and Y resolution as you need it, and chose 3 cells in the Z direction.
3) In the adaptation step, do not define any refinement but set the top and bottom boundaries as "Used for trimming". (You will have just one layer of cells in your domain after that step)
4) In the expert parameters of the snapping step, deactivate the "buffer insertion" option
5) In the viscous layer step, define on the bottom boundary the viscous layer you need as background mesh
In a second project:
6) Create a 2nd domain of the same dimension as the 1st domain, but which includes you geometry
7) At the Initial Mesh step, chose the option "Import mesh" and import the mesh from the first project.
8) Define the remaining mesh parameters as usual.
It is not exactly what you asked for but I hope this helps
Eloise is offline   Reply With Quote
gradient boundary, wind
simulating wind shear profile for a wind turbine--> How??? mohammad CFX 14 August 25, 2014 09:09
vortex cause pressure gradient or pressure gradient induce vortex? fruitkiwi Main CFD Forum 4 June 12, 2012 01:12
simulating wind shear profile for a wind turbine--> How??? mohammad FLUENT 0 April 14, 2012 23:54
Simulate the wind profile on a wind turbine---> HOW ???? mohammad Main CFD Forum 0 April 13, 2012 08:07
Inlet Flow Velocity or pressure gradient - modeling of a Wind Turbine Blade case LittleBart Main CFD Forum 5 January 10, 2011 15:07
