Home > Forums > Software User Forums > Fidelity CFD
NUMECA crash during mapping
Old   January 16, 2013, 04:00
Default NUMECA crash during mapping
bkrdnr is on a distinguished road
Hello all,
I am working on an FSI problem. I want to map the pressure output of the CFD calculation onto the FE mesh from ANSYS. I have generated a FE mesh and write it by using the CDWRITE command as a .cdb file. I am using this cdb file as the input in NUMECA/outputs/ANSYS. Unfortunately, NUMECA crashes when it reads the input file and gives the error which I posted below. I am working with Linux but the same problem occurs with windows too.
Did anyone have the same problem before?
WARNING: ANSYS VERSION 14.0.3 IS NOT SUPPORTED (> 8.0)!
TRY TO READ THE FILE
STOP THE READING ONLY IF A PROBLEM IS DETECTED
At line 282 of file _src/_FEmodel-interaction/ReadANSYS.F
Fortran runtime error: Bad value during integer read
bkrdnr is offline   Reply With Quote
Cht tutorial in 15 braennstroem OpenFOAM Running, Solving & CFD 197 June 10, 2015 03:02
Parallel computation using NUMECA 6.1 BalanceChen Fidelity CFD 1 June 5, 2011 06:24
solid to fluid heattransfer with chtMultiRegionFoam nakor OpenFOAM 11 March 21, 2011 08:28
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
New NUMECA Forum Opened Jonas Larsson Main CFD Forum 0 February 16, 2003 10:25
