Home > Forums > Software User Forums > Fidelity CFD
mass flow rate
Old   March 7, 2013, 12:48
Default mass flow rate
mattyo is on a distinguished road
I'm working with simulations of tube which had one inlet and the two outlet by using FineHexa.
The problems is how can I know the value of outlet mass flow for each outlet.
The default of FineHexa only show the total of the outlet mass flow so I cant determine the mass flow rate for each outlet.
Please help me..
Thank you..
mattyo is offline   Reply With Quote
Old   May 13, 2013, 14:01
Hamid Zoka
Hamidzoka is on a distinguished road
It must be an easy task in the post processor.
Even if could not do this, simply give different names to your outlet boundaries, e.g. outlet1 and outlet2. So you can separately check their mass flow rate via CFview.
Hamidzoka is offline   Reply With Quote
Old   June 24, 2013, 10:53
CJ
oldshoes81 is on a distinguished road
Send a message via MSN to oldshoes81 Send a message via Skype™ to oldshoes81
Try this, the mass flow rate is equal to density * velocity * cross section area. To differentiate the both, say :
Mdot @ OUTLET 1 = density*velocity@OUTLET 1*Cross section Area@OUTLET 1
Mdot @ OUTLET 2 = density*velocity@OUTLET 2*Cross section Area@OUTLET 2
Where i assume the density is constant in the system.
Regards
CJ
NUMIT Enterprise, Malaysia
+6 017 656 3436
http://maccom-numit.blogspot.com
http://www.numit.com.my
Email : seiko.q@numit.com.my
oldshoes81 is offline   Reply With Quote
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 09:58
CFX turbo - Mass flow rate Vashishth Patel CFX 7 April 3, 2014 20:33
Mass flow rate at the outlet tejasvikrishna FLUENT 2 May 25, 2013 02:42
negative global mass flow rate Gimli FLUENT 0 April 21, 2006 07:17
mass flow rate error Masood FLUENT 0 May 22, 2005 00:32
