Home > Forums > Software User Forums > Fidelity CFD
Streaking (air under hull)
Old   September 8, 2014, 08:51
Default Streaking (air under hull)
Loulou is on a distinguished road
Hi everybody,
I'm a Fine Marine user and I often get some streaking troubles on hull. I try a lot of settings and didn't find a process to avoid it.
The bows of the studying boats are not in the water so the contact between solid and fluid is under the hull in a flatter area than a traditional bow.
I would like to avoid using unsteady computation to save time. streaking appear for speed higher than 5m/s.
I try a lot of things :
- Use quasi-static in order to fix the box until t = 1.5 * acceleration time
- decrease the time step
- Make a refinement box on the bow to define the Free surface to LOA/1000
- Change Y+ (from 100 to 300)
-I use acceleration ramp as tacc= 2*Lref/Vref, I try to increase it
-Use adaptive grid refinement
-Increase the diffusion to 5
I will be really happy to have new ideas and to hear from your experiences.
Thank you
Loulou is offline   Reply With Quote
Old   September 8, 2014, 19:02
laurentL
laurent98 is on a distinguished road
hi Loulou,
the only way i found to get rid of this "numerical ventilation" is to play with the pressure threshold . after one computation you look at the pressure on hull, where you want water (for exemple 800...) then you set the parameter (Uw?) to -800
hope it's help?
that was working very well for me.
laurent98 is offline   Reply With Quote
Old   September 9, 2014, 09:35
Hi Laurent,
thank you for your answer, I tried on light model without Viscous Layer and the streaking disappear. Do you still apply the same coefficient or you always run a first calculation to see if there is streaking and use the correction after that. Because in my case, 70% of my computation have streaking, so it can take a long time to test each computation before having the coefficient?
What about using the coefficient range [0;1]?
Thanks
Old   September 9, 2014, 15:40
laurentL
hi,
it a numerical problem because of the viscous layers.
fist you must add the streaking corrector CIStreakCorrection. if streaking stay then use uwCoefCorrection.
Uw depend on the shape of hull, but mostly of the speed, so after some test you will have a good idea of the right value. by looking at the pressure on hull of the computation you already make you have the threshold. by using the automatic way, i had a lot of wrong computations because FM add water where it was not realistic...
cheers LL
finemarine, streaking
air under hull, alpha.water=1 threshold pressure laurent98 OpenFOAM Programming & Development 2 September 8, 2014 11:47
Radiation interface hinca CFX 15 January 26, 2014 17:11
air under hull laurent98 Fidelity CFD 4 February 18, 2013 09:27
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
Help!!!problems in air jet into water bath kim FLUENT 4 June 9, 2003 07:04
