September 8, 2014, 13:03 |
Negative Volume In Block
Amirah
Rep Power: 12 |
This problem make the solver crashed. "Computation stop because of negative volumes. Negative volume found in block." How to overcome this problem? What should I overlook? Thank you. |
September 11, 2014, 06:47 |
Romain
Rep Power: 17 |
Did it crash soon after the run started ? Are you using mesh deformation ? Do you witness significant amplitude motions ? It may be that at t=0s the body is quite far away from its final position, which leads to significant mesh deformation, which can lead to negative volumes. |
November 19, 2014, 19:16 |
Rep Power: 14 |
You have to carefully check your mesh generation process. A common error is related to Unit value: double check it.
You may also try to refine the grid close to gaps or fillet (if there are any). www.ampsolutions.it |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
Negative Volume during Mesh Motion Analysis | giov_ingr | FLUENT | 2 | December 13, 2013 07:09 |
Courant number blowing up, non-orthogonal mesh? | odellar | OpenFOAM Running, Solving & CFD | 5 | October 22, 2013 20:50 |
Possible bug in blockMesh | benru | OpenFOAM Bugs | 16 | August 17, 2013 20:54 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
